11-22-2012, 04:08 PM | #5376 |
Re: What did you do to your truck today!
Finished the install of my 60/40 Tahoe seats
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-22-2012, 04:16 PM | #5377 |
Let's see em'. I have some I've yet to install.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
11-22-2012, 04:23 PM | #5378 |
Uneasyrider, looks like you've got the most important tools out and in use...
11-22-2012, 10:58 PM | #5379 |
Technically this was yesterday, but you get the idea.
11-22-2012, 11:24 PM | #5380 |
I'll try and get some pics friday
11-22-2012, 11:34 PM | #5381 |
Went shopping yesterday. New wires, plugs and guides tomorrow.
11-23-2012, 06:13 PM | #5382 |
Yes Sir. A little liquid to get the job done!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
11-23-2012, 07:38 PM | #5383 |
Grand PooBaa Member
Like how this sits, is it static or an airbag drop?
11-23-2012, 07:52 PM | #5384 |
11-23-2012, 07:56 PM | #5385 |
Sorry, I forgot. Here's my link with a little info if you were thinking of going that route with your stepper.
http://67-72chevytrucks.com/vboard/s...d.php?t=545435 |
11-23-2012, 11:48 PM | #5386 |
got my cm prepped for running the exhaust through it. I gotta cut the tubes a lil' shorter before welding them in. I just might cut one in half and use the two halves.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-24-2012, 12:55 AM | #5387 |
Junior Member
My son drove my '67 swb steeper out to my house in the country today, first time on the road since we just finished building it.
Just one slight problem, it died and would not start about 3 blocks from my son's house. We went back to my son's and got some supplies and tools. He checked for spark-ok, checked for fuel at carb, none. He finally isolated it to the tank as being why there was no fuel getting to the carb. He removed the pickup tube/sending unit and found that the sock had broken apart and plugged the pickup line. Got the line all cleared out and away we went, it got home ok.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
11-24-2012, 01:04 AM | #5388 |
Today I yanked the old, dead I6 250 out of the engine bay. Tomorrow I hope I will be posting that the new, healthy I6 250 is put together from breather to oilpan and back in the truck.
11-24-2012, 01:17 AM | #5389 |
Got dash back together, new ac vent hoses, new vacuum hoses on heater/ac control, new fan switch, new speaker, installed underdash lights and glovebox light purchased from forum member, new glovebox cardboard, installed blue leds in cluster, radio and heater/ac control unit. Installed new fan shroud also purchased from forum member.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
11-24-2012, 03:15 AM | #5390 |
Old member
Well I got the SS steering wheel mounted and the new air horns work great with the new horn button.
I installed a set of the Chevy horns a few weeks back. Can you hear me now! I think so.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-24-2012, 04:28 AM | #5391 |
got more parts in the mail!! woohooo
11-24-2012, 01:19 PM | #5392 |
Heres the seats 60/40 split 99 Tahoe seats ,good junkyard find ($100)
11-24-2012, 01:34 PM | #5393 |
Wow $100 bucks :O man crazy good price and looks great.
Posted via Mobile Device |
11-25-2012, 12:11 AM | #5394 |
Cool Truck
Finally wired up the reverse lights to my LED lightbar
Posted via Mobile Device Posted via Mobile Device
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
11-25-2012, 12:42 AM | #5395 |
Painted my frame and re-installed brake booster.
Superman |
11-25-2012, 01:00 AM | #5396 | |
Grand PooBaa Member
Thanks for the link. I was going to pull a trailing arm setup from the wrecking yard, just did not know if I needed the complete rearend, or just the arms and u-bolts. |
11-25-2012, 02:57 AM | #5397 |
I found some good deals around Town on some truck parts.
Bought a new cowl hood.... Also ended up bringing home a new TV.....
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
11-25-2012, 11:59 AM | #5398 | |
I have a rear axle, trailing arms, u-bolts, shock crossmember, shock mounts and anything else you need to convert from leafs to coils. Dano
'69 Fleet It ain't yours, if you didn't build it! |
11-25-2012, 04:05 PM | #5399 |
11-25-2012, 09:43 PM | #5400 |
Used left over seat material for my sub box
