Old 11-22-2012, 07:27 PM   #1
1968vetL-71
Junior Member
1968vetL-71's Avatar
Correct gears with a 4l80?
I was wondering if anyone was running 35"-36" tires with a 4l80e and 3.73 gears? If so, is the OD useable or do I need to bump up to 4.10's or 4.56's to get the rpm's in the right range so it's not bogging down? I've always ran a manual trans in all my trucks so it never really mattered too much. I have a 4spd/205 vss setup I can run instead of the 4l80/205 vss combo if I'm not getting the use of OD out of the auto. Hate to waste it if its not beneficial. Any info is appreciated.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 11-22-2012, 08:52 PM   #2
bilfman
bilfman's Avatar
Re: Correct gears with a 4l80?
I have 32" tires in my 4l80 swap and run 3.73 gears this spins me around 1850rpm at 60. A little low for my liking but I just completely rebuilt both front and rear diffies this past spring so I'm not going to open them up just yet. I think 4.10 would be my minimum with 32" tires, money not an issue, that would be for my liking.
So for your question, with my 3.73s, 32" and od it is just fine for cruising. But when I pull the big boat I find myself needing to shift to 3rd occasionally. I am currently redoing some 781 heads with a bigger exhaust valve and roller rockers. Also switching to a stouter lower rpm cam to bump my power and torque for pulling to help 4th towing out.
So I am thinking with 35's 4.10 or 4.56 is the way to go. I had 4.56's before I had the 4l80 and wish that I had that back.
Hope that helps.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 11-22-2012, 10:19 PM   #3
b454rat
Depends on what motor your running. My father used to have a 98 2500HD 454/4l80 that had a 6" lift and 35s w/3.73s in it. Truck would friggin move. I had a 97 that was stock with same motor/tranny but with 4.10s and 285s, didn't have nearly the power. But, I think it had issues just before it got sold.
If your running a small block, might want to go with at least 4.10s.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-23-2012, 03:16 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
4L80e OD ratio is .75
35" tires at 65mph and 3.73 gears = 1746 rpm
36" tires at 65mph and 3.73 gears = 1697 rpm
35" tires at 65mph and 4.10 gears = 1919 rpm
36" tires at 65mph and 4.10 gears = 1866 rpm
35" tires at 65mph and 4.56 gears = 2134 rpm
36" tires at 65mph and 4.56 gears = 2075 rpm
here is a link to the calculator I used...
http://www.csgnetwork.com/multirpmcalc.html
I have a 4L80e going in my Blazer with 4.10s and I'm looking at 35" tires that are more like 34". Check with the tire manufacturer for actual diameter...
Rich
1972 K5 Blazer CST Click HERE
Old 11-26-2012, 07:08 PM   #5
kwmech
The 4.56 gearing with the 25% overdrive equates to final drive of 3.42. So 3.42 final gearing with a 35'' tall tire would be good. When I had my suburban I geared it with 4.56s and was running a 700r4. drove really nice, that was with a 285-16'' tire which was a bout 31.5'' tall. So, I would go with the 4.56s
Old 11-26-2012, 08:49 PM   #6
1968vetL-71
Junior Member
Thanks for the input gentleman! I can't decide if I want to keep my auto or convert to 4spd. I have everything to do so including a 4spd tilt column with cruise!! Well see how lazy i want to be. lol. But I'm thinking a loaded 91 crew with a stick would be cool. Thanks again.
