Old 11-23-2012, 07:12 PM   #1
pontgta
pontgta's Avatar
Dual fuel Tanks
Ok, so i finally got all parts to put the dual fuel tanks working....But hooked all up and only the right side(passenger) works... Bought new 6 port valve because i had none.... I have looked at the wiring diagrams, and i a bit confused... Should i have 12v at the selcetor switch? what actually makes the valve work?
pontgta is offline   Reply With Quote
Old 11-23-2012, 07:23 PM   #2
pontgta
pontgta's Avatar
Re: Dual fuel Tanks
i do have 12v to the fuel pump(drivers side) when i am cranking
Old 11-23-2012, 07:51 PM   #3
hatzie
Moderator
hatzie's Avatar
Re: Dual fuel Tanks
Which valve did you install... Single wire or WeatherPak plug?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-23-2012, 08:03 PM   #4
pontgta
pontgta's Avatar
Re: Dual fuel Tanks
6 port valve... 5 wires i believe....Used the original harness...
Old 11-23-2012, 09:50 PM   #5
makman1297
makman1297's Avatar
Re: Dual fuel Tanks
You can goolge the wiring diagram, thats what i did for mine, but you have a wire in from each tank for the level, on that goes to the gas guage, and then the other two are + and - that switch polarity from the switch for the position. So you 12v is at the swich.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 11-23-2012, 10:07 PM   #6
pontgta
pontgta's Avatar
Re: Dual fuel Tanks
ok seems i do have 12 volts at the switch,but only while cranking....
Also I think my new valve is bad... Had an old valve and ran a bench test valve makes noise and can switch polarity...works both ways. the new valve does not even make a sound...
Old 11-23-2012, 10:12 PM   #7
makman1297
makman1297's Avatar
Re: Dual fuel Tanks
http://67-72chevytrucks.com/vboard/s...d.php?t=492270 try the diagram on this one.
2007 Chevy Suburban
Old 11-24-2012, 01:02 AM   #8
hatzie
Moderator
hatzie's Avatar
Re: Dual fuel Tanks
PDF scans of almost all of the OEM 73-91 CK RV GM wiring diagrams can be found by following my signature link. The fuse panel socket details are on the first page or two after 1986.
The fuse panel has several aux power sockets that change based on ignition switch position. I think there is at least 1 fuse panel power socket that's only hot in the Start position. The tank system should be plugged into one of the fuse panel "A" sockets that are hot with the ignition in the Run position only.
Old 11-24-2012, 04:16 PM   #9
pontgta
pontgta's Avatar
Re: Dual fuel Tanks
.....Yes i am excited because after a good night sleep....I got it to work.... I went back to the basics. I took the supply line from the left tank to see if i had fuel coming out ....it was dry, but when i took the return line off it was wet, so took the tank down again....And yes i crossed the line some how at the tank...it was dark when i put them on... So i rearranged tmy lines...cranked it .....and i heard the engine roar....only took me an an hour today,,,,,,what a pain...but in the end its all worth it....I have dual fuel tanks working....
Thanks for the schematics.....they were a help....found out the power comes from the fuel pump relay.......so once i had that it was on....
Thanks again everyone...
