Old 11-28-2012, 02:55 PM   #1
1978chevybigten
1978chevybigten's Avatar
Trans problems
Got the fresh rebuilt trans in last night thought everything was going good. Go to drive today and she's stuck in 1st. What could cause this? The modulator is hooked on the carb I'm going to switch it to the intake. Could that be the problem?
1978 big ten 350/350:chevy
1978chevybigten is offline   Reply With Quote
Old 11-28-2012, 04:36 PM   #2
1978chevybigten
Re: Trans problems
Switch the vac to the manifold and got the same results. It won't even up shift in manual. My neighbor took it for a spin and said the valve body is sticking. When we installed the shift kit. The 2-3 shift assembly was sticking. And the valve body was burred. We sanded them down but maybee we didn't get them all. Should I try to fix that or just buy a new valve body?
Old 11-28-2012, 04:37 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Trans problems
What trans? Modulator should be hooked to full manifold vacuum. If the shop is ignorant in transmission building beat practices they could have taken the valvebody apart and not deburred any of the valves or gotten rag lint on them. Either causing a stuck valve.
Also check your linkage make sure it's adjusted correctly
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-28-2012, 04:42 PM   #4
1978chevybigten
Re: Trans problems
Th350 We rebuilt it. It's hooked to manifold, we deburred All the valves and used compressed air to clean it. And the linkage is adjusted correctly to my knowledge. I'll double check. Would the best bet be to drop the valve body and re clean everything?
Old 11-28-2012, 05:25 PM   #5
INSIDIOUS '86
Re: Trans problems
Yah drop it and run through the valves again. Check the valve size and the body bore size. If they are loose then it's possible they can jam slightly sideways and that means the body needs to be replaced
Old 11-28-2012, 06:13 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Trans problems
My tranny builder said a valve may get stuck because of a shift kit. He gave me these instructions.
Speed up in Drive, drive just about the point it shifts to 2nd, turn off engine (don't lock the steering wheel!), let it roll forward a few feet then crank it back up, slow down and speed back up. It should unstick the valve.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-28-2012, 08:26 PM   #7
clinebarger
Re: Trans problems
Pull the governor, Inspect for a stuck valve....Hold the weights closed & shake the governor....Should hear the valve "rattle".
Check for a stripped or apple cored governor gear.
clinebarger is offline   Reply With Quote
Old 11-28-2012, 08:28 PM   #8
1978chevybigten
Re: Trans problems
Thanks for all the info guys, I'm going to replace the governor the gear was chipped a little and pull the valve body and see what's going on. If I can't fix it I'll buy a valve body from summit.
Old 11-29-2012, 10:11 AM   #9
sqzbox
Re: Trans problems
Woah bud, Change the gov first. 1 thing at a time. If that doesn't work, then go for the valve body.
sqzbox is offline   Reply With Quote
Old 11-29-2012, 10:26 AM   #10
1978chevybigten
Re: Trans problems
Thats what I was planning on.
Old 11-29-2012, 10:54 AM   #11
rs72z
rs72z's Avatar
Re: Trans problems
This^^^^^
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 12-01-2012, 02:48 PM   #12
1978chevybigten
Re: Trans problems
Replaced governor. Nothing changed, talked to a local trans shop and he rebuilds th350's for $300 -_- we have already spent that and plus some. Guess I should have got some quotes first lol. Going to drop the valve body. It's possible I used the wrong gasket? I guess we will find out.
Old 12-01-2012, 10:42 PM   #13
1978chevybigten
Re: Trans problems
pulled the valve body and the 1-2 valve was stuck. got everything smooth and moving good. going to put everything back together and hopefully fix the problem.
Old 12-01-2012, 11:00 PM   #14
INSIDIOUS '86
Re: Trans problems
Sounds good. Let us know!
Old 12-02-2012, 06:30 PM   #15
1978chevybigten
Re: Trans problems
Got everything back together now fluid and test. Hopefully she shifts!
Old 12-02-2012, 07:58 PM   #16
1978chevybigten
Re: Trans problems
Well she's still in first, I think the shift kit plate is causing it. The gaskets they sent dont match the plate they sent us. Or any of the bolt holes and now I can't find the original plate. Im surrendering and taking it into the trans shop.
Old 12-02-2012, 08:19 PM   #17
INSIDIOUS '86
Re: Trans problems
What kit was it?
Old 12-02-2012, 08:41 PM   #18
1978chevybigten
Re: Trans problems
its a trans go from rock auto atp makes them.
Old 12-16-2012, 01:05 PM   #19
1978chevybigten
Re: Trans problems
trans has been in the truck for a week and is shifting good! very pleased the builder took out the spring cushion and added another steel. and the reason for the trans not the shift was i put the detent control valve in the wrong way. so it wouldnt upshift.
