#251 |
Re: How about some pics of Static dropped 60-66
Here is mine:
4" front 5" out back, cpp coils ![]() |
#252 |
Beautiful! What size rims and tires do you have on that?
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
#253 |
Thanks for the compliments. Nitto 555's, 245/40 18 front and 285/30 20 rear. Forgot to add cpp c-notch welded in rather than bolted.
Posted via Mobile Device |
#254 |
![]() Join Date: Nov 2010
Nice!!! 65shortbox Lets see more pics! like interior and under hood
LIFE IS SHORT HAVE FUN |
#255 |
Quick question on the static dropped trucks. How many of you are notching the frame in the rear? I'm dropping a '64 long box, looking at "5 drop coils, or a combination of blocks & coils totaling "5 in the rear and wondering how necessary a set of bolt-in c-notches would be? Any opinions? Maybe pics of how close the rear axle is to the frame in your static drop setup?? Any info is much appreciated!!!!
#256 |
I am not sure of the "magic number" where you would add c-notch but I have had three of these trucks, two lowered, and the short bed was the lowest. I added the c-notch because it felt like I would lose control when on the freeway and hit a bump on the road. At first I could not figure it out because bumpstops are rubber and soft. Thought maybe it was the front end/bumpsteer. I noticed when I would add a decent load out back the axle was resting on the bumpstops. After I installed the c-notch it made a world of difference in ride quality and highway speed stability. I HIGHLY recommend it when lowering these trucks any significant amount like you propose. Maybe check distance between bumpstops and axle after you drop the truck to be sure. Just my .02...
#257 |
![]() Join Date: Sep 2011
Hey Polaris,
The "rule of thumb" is anything over 4 inches should be notched. I'll post up a couple of pictures soon, but I just completed a 4 inch coil drop and my spacing is fine. However, if I were to go any lower, I'd definitely notch the frame.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#258 |
Thanks for the replies, that pretty much answered my question. Since I'm gonna have the box off it over the winter, I'm thinkin it'd be a smart time to go ahead with the notches. Thanks again!!!
#259 |
![]() Join Date: May 2012
This is at 5-1/2" in the front and 6-1/2" in the rear as measured from the floor to underside of main frame rails directly below front and rear cab mounts.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
#260 |
made in america
that is so bad ass lookin. love it
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree ![]() 2004 corvette- lowered, borla, tuned. slow ![]() my old girl 1966 c10- 305v8, t-5 sold |
#261 |
Its bad a$$ alright!!! I love it too!!!
#262 |
DURG? What size tires are you running?
#263 |
265-40-22 and 245-40-20 Nitto NT555 Extreme ZR
#264 |
CPP 4/5 kit.
#265 |
#266 |
#267 |
1 coil cut from front.
#268 |
Durg, lookin awesome, would love to see it all together!!
#269 |
The 60-66 GMC/Pontiac guy....
I have gone through this thread and see a lot of cool trucks.
There is a lot of hard work showing in those photos. Nice job guys. What I am wondering is where are the photos of the suspensions? I am specifically looking to find information on coil over front and rear static suspensions. I was going to do air springs but can't find a system that has a single set ride height as I do not want to have a variable system. So I was thinking a static coil over system would be best for what I am doing. Does anyone know if there is anything available on static coil over suspensions and if so where? ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#270 |
Durg's is static drop ridetech coil over. Check his thread, GREAT work on his truck.
#271 |
So where is his build thread?
#272 |
I found this thread.. cool static rear suspension
http://67-72chevytrucks.com/vboard/s...d.php?t=550139 ![]()
#273 |
Right in the 60-66 project section.
#274 |
I'm gonna try.[IMG]pc130043[/IMG]
#275 |
Nope, guess I'll have to try something else!
