Old 10-23-2003, 07:06 PM   #1
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Lowering shocks and springs
I currently have Belltech lowering springs and shocks,
I think they suck, and they are way too springy. It slike the rear ones arent there at all, and the bed hops and rattles over bumps.
My question is, how low can I go with just shocks and springs
with 4 wheel drums? I want something with a nice firm ride
and with about a 4" Drop. Can I do this, or do I have to go with drop spindles, and disk brakes?
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 10-23-2003, 07:28 PM   #2
DavidM
DavidM's Avatar
good drop springs
Well I have 2 1/4 inch drop spindles on the front and 4 in drop springs on the back of my 67 and they ride very good not to bouncy I got mine at http://www.mcgaughysclassic.com/
They where very prompt and knew what they where talking about
hope this helps....
David M
Proud Owner
Of A 67 C10
Heres my truck so u can See
http://67-72chevytrucks.com/vboard/s...threadid=74108
DavidM is offline   Reply With Quote
Old 10-23-2003, 08:48 PM   #3
WB72
Before and After
WB72's Avatar
With a 4" drop in the rear, do you have to notch the frame?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 10-23-2003, 08:58 PM   #4
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
No you do not have to notch the frame with a 4" drop... In fact early classic says you don't even have to have a notch with a 6" drop.... The only thing IMO is you won't be able to load very much at all in your truck with a 6" drop and no notch.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-23-2003, 09:05 PM   #5
gr8scott51
gr8scott51's Avatar
ECE
I bought the Early Classic Enterprises 3/5 set up with new springs, KYB shocks, adjustable panhard bar, & shock mounts. It may not be as low as you want, but it's still load rated at a 1/2 ton and doesn't ride like a ferry boat.
Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 10-23-2003, 09:58 PM   #6
DanoDMano
DanoDMano's Avatar
gr8scott51 that is an awesome description of the ride I am experiencing!! How much can I expect to pay for that setup you described??
I can also grab my bed with my hands and it rattles. The only place it is coming from is the shocks. If I hole the panhard bar and shake the truck it is quiet, and the panhard is not loose.
Power Locks,
Truck Photos
