Old 11-29-2012, 07:12 PM   #1
UKNOWME
UKNOWME's Avatar
McGaughys Spindle problem
I have read many people comment about having to grind the lower control arm when using drop spindles and 15x8 ralley wheels but has anyone had to grind the spindle itself. The spindles are rubbing on the inside lip. I am planning on ordering new Wheel Vintique ralley wheels so can i just change the offset? Thanks
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 11-29-2012, 07:30 PM   #2
durty harry
durty harry's Avatar
Re: McGaughys Spindle problem
No problems with mine.
I have 8in ralleys with 4 in bs
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 11-29-2012, 08:27 PM   #3
UKNOWME
UKNOWME's Avatar
hmmmm! Same brand spindles? 2.5 drop?
1964 Chevy c10
Old 11-29-2012, 08:29 PM   #4
UKNOWME
UKNOWME's Avatar
Maybe my stock 8s are a different backspace?
1964 Chevy c10
Old 11-29-2012, 08:36 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Shouldn't be.
Got any pics?
Keith
Convert to disc brakes.
Old 11-29-2012, 08:41 PM   #6
UKNOWME
UKNOWME's Avatar
The wheels or the spindle? Either way I'll take some tomorrow. I'll measure the backspace too.
1964 Chevy c10
Old 11-29-2012, 08:56 PM   #7
Mangled03gmc
I do know that some spindles specify that X size wheels need to be ran or will have the problem your describing.
John
Mangled03gmc is offline   Reply With Quote
Old 11-29-2012, 09:19 PM   #8
J Knight
J Knight's Avatar
I have 2.5in McGaughys drop spindles with 15x6.5 van rally wheels, they have 4.25in backspace wich is the same as stock 15x8 rallys. I had to grind a little off the leading lower edge of the lower control arms to solve the rubbing issue.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-29-2012, 09:23 PM   #9
87squarebody
87squarebody's Avatar
On my bell tech 3"spindle with a 2" spring if you jack the truck up the spindle hits the dish on my 15x8 rally's but when you set the truck down on the ground the spindle doesn't hit and never hits while driving plenty of clearance.Hope this helps I know they are different brands.
87squarebody is offline   Reply With Quote
Old 11-30-2012, 11:30 AM   #10
UKNOWME
UKNOWME's Avatar
I do have 2" drop coil also and have not even checked with it on the ground. Currently it's just a rolling chassis so I might have to wait until I put at least the drivetrain back in to verify. Thanks for the info though that is great knowledge
1964 Chevy c10
Old 11-30-2012, 11:31 AM   #11
UKNOWME
UKNOWME's Avatar
Yeah I knew about the control arms but not the spindle
1964 Chevy c10
Old 11-30-2012, 11:36 AM   #12
J Knight
J Knight's Avatar
What part of the spindle is rubbing? On mine the spindle is very close to the wheel lip where the tie rod connects, it actually knocked my wheel weights off.
John
Old 01-11-2014, 01:37 AM   #13
woodfork1
I'm having the same problem. Anything that can be done with out grinding. I want to replace the wheels in the future when the funds permit.
woodfork1 is offline   Reply With Quote
Old 01-11-2014, 02:20 PM   #14
woodfork1
here's a another picture. I really dont want to buy new wheels and tires now.
