Old 11-30-2012, 09:13 PM   #1
bohmankid
bohmankid's Avatar
EGR block off
on the 5.3 intake manifold, what are you using to block off the EGR without it leaking? I don't want to spend $30 bucks for a block off plate.
bohmankid is offline   Reply With Quote
Old 11-30-2012, 10:43 PM   #2
harnalien
TruckincrazY
harnalien's Avatar
Re: EGR block off
I used GM Part #12558346 for mine, but I can't seem to find it for sale anywhere online. Maybe the dealer can still get it. I also remember a 1 3/8" freeze plug is an option as well.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 12-04-2012, 12:31 AM   #3
71chevystep4x4
71chevystep4x4's Avatar
Re: EGR block off
I see a lot of guys using the 1 3/8 freeze plug, but am curious as to how one would go about installing, or fastening it in to stay? just silicone it?
71chevystep4x4 is offline   Reply With Quote
Old 12-04-2012, 02:10 AM   #4
bohmankid
bohmankid's Avatar
Re: EGR block off
I went with the freeze plug. It is a Dorman brand and the part number is 555-093.1. It cost me a total of 0.99 cents plus tax. the hole to fill for the EGR is 1.375-inches and the size of the plug is 1.379-inches. I just pushed it in there and tapped it a bit with a tiny hammer.
Old 12-27-2012, 11:04 PM   #5
bohmankid
bohmankid's Avatar
Re: EGR block off
I got rid of the exhaust manifolds and replaced with long tube headers. That solves that problem.
OR You can simply get a flat piece of steel and cut it to the size of the port, and drill two holes, make sure you use the gasket. Ebay also has people selling egr block off kits if you're down to spend some money (not worth it to me). Good luck with your project.
Old 12-27-2012, 11:07 PM   #6
hilljob26
hilljob26's Avatar
Re: EGR block off
i guess i will need a plug....that egr looks hidious...do you just take those wires out of wiring as well so the computer doesnt see it,or is there another way around it
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 12-27-2012, 11:19 PM   #7
bohmankid
bohmankid's Avatar
Re: EGR block off
You can take the wires out, but your computer will need the codes deleted so it doesn't throw an engine code. I'm sending my computer to Brendan at lt1swap.com.
Old 12-27-2012, 11:31 PM   #8
hilljob26
hilljob26's Avatar
Re: EGR block off
i see
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 03-29-2013, 07:35 AM   #9
slamed67
slamed67's Avatar
Re: EGR block off
awesome! answered my egr questions here :]
slamed67 is offline   Reply With Quote
Old 03-29-2013, 08:28 AM   #10
OKGMC4
OKGMC4's Avatar
Re: EGR block off
I used a rubber freeze plug but was afraid it would eventually pop out so I once it was flush I used a fender washer on the bolt hole above it to retain the plug as added insurance.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-29-2013, 08:50 AM   #11
slamed67
slamed67's Avatar
Re: EGR block off
i like that air cleaner dude! did you fabricate that? oh and will it be the same size plug for every year 5.3?
Old 03-29-2013, 09:40 AM   #12
OKGMC4
OKGMC4's Avatar
Re: EGR block off
Thanks. I made it with a cardboard box. Wrapped it in saran wrap and glassed it, then cut a hole to fit a K&N I had laying around and pulled out the box. The lid is phenolic but could be wood, cut and routered to fit the panel filter. I tacked 1/4-20 nuts to fender washers and gorilla glued them to the inside for the bolts on top. The cage that holds it is 1/2 square tubing bolted to the fuel rails. Probably could have just went with a cone but I already had the stuff to make it and this thing gets a ton of looks anywhere I pop the hood.
