Old 12-01-2012, 12:36 AM   #1
dukcaln
dukcaln's Avatar
72, water on floor board, from?
ok, I had the truck since summer and now that it is raining pretty darn good I noticed the passenger side floor was wet. I know I have a new window and window seal on the front and door trim seals. so my question is, where are the possible locations and or places on the cab that will leak... where do I start looking
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 12-01-2012, 12:41 AM   #2
jocko
jocko's Avatar
Re: 72, water on floor board, from?
i think you may have answered your own question. Before I read the second half of your thread, I was going to guess the window seal. Then when I read you just had the window+seal replaced, that kind of seals the deal (no pun intended). if you paid a shop, take it back and have them re-do, even though a pain in the butt. Possibly lower passenger side of windhsield seal leaking.
Old 12-01-2012, 12:44 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
Underneath the cowl there are quite a few areas where there are sealant where parts come together. Over the years this sealant will harden and crack.
Also water can come in around the windshield wiper motor shaft under the cowl.
These are just a few areas, hopefully others will add more info.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-01-2012, 12:46 AM   #4
dukcaln
dukcaln's Avatar
I know its not the window or seal. replaced in summer, numerous wash jobs and no leaks..... I will look undedr the cowl and surounding areas
SOLD 1972 chevy c10
Old 12-01-2012, 12:56 AM   #5
Hutch
Hutch's Avatar
Maybe the antenna cable hole in the cab
Cowl vent drain clogged with leaves
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 12-01-2012, 01:11 AM   #6
Frkypunk70
Frkypunk70's Avatar
I know my truck personally does this only when I take it through the car wash. I end up with a pool of water on the passenger side floor mat. On my truck it is a hole in the cowl that drops straight down into the passenger floor. It's not big but you notice it when you pressure wash it. Try on a sunny day looking up from your passenger side floorboard you will see where the water is coming from.Must be a Chevy thing.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 12-01-2012, 01:17 AM   #7
vectorit
What?
vectorit's Avatar
Check the antenna cable, and where it comes in from the outside.
Have seen it where the water will follow the cable, and drip where the cable droops the lowest. Usually right where the passengers feet would be.
Take some silicone and seal the hole where the cable comes through.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-01-2012, 02:26 AM   #8
jocko
jocko's Avatar
Ah, sorry, I kinda read your thread thinking you replaced them and then, all of a sudden, a leak... If lots of water exposure and no problems, then no, probably good there. Once a new seal is proven good, it'll be good a long time probably. Sorry bout the confusion.
Old 12-01-2012, 02:34 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
I agree on the inner cowl being suspect #1. My 67 had a spot where the sealer was out and leaked onto the passenger floorboard.
Old 12-01-2012, 05:44 AM   #10
rpatowers
When mine leaked it was through the hole for the antenna wire. There is a rubber gromit that fits into this hole and allows the wire to run through it. I popped the gromit back into the hole and haven'tad a problem since.
rpatowers is offline   Reply With Quote
Old 12-01-2012, 10:11 AM   #11
slikside
slikside's Avatar
X2 on seam seals on fwd cab. That's where mine leaked.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 12-01-2012, 10:39 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
So, your kick panels are rust-free? Is there no dirt/trash accumulated in the base of that panel, like just inside the vents?
The previous owner of my truck was trying to find the source of similar leaks to your and used the wrong silicone sealer and created a swiss-cheesed firewall, along with a lackametal around the wiper motor....which fell out one morning....in the rain.
So, after you take the plenum grille off from in front of the windshield, you'll have better views.
Member Nr. 2770
Old 12-01-2012, 11:54 AM   #13
Daddy'O
Daddy'O's Avatar
Possibly your heater core?
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 12-01-2012, 12:23 PM   #14
Square_78
Square_78's Avatar
check your drip rail sealant above the windshield. If its old and cracked that could be a problem also.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 12-01-2012, 12:35 PM   #15
yuccales
yuccales's Avatar
This was my problem. I'd get an inch of water in the glove box. I watched water follow the cable then drip into the stapled side of the glove box. Giant blob of RTV on the antenna cable hole, problem fixed.
yuccales is offline   Reply With Quote
Old 12-01-2012, 12:46 PM   #16
dukcaln
dukcaln's Avatar
i will pull her in the garage today and take a look....... thanks all for the possibles
SOLD 1972 chevy c10
Old 10-29-2014, 11:13 PM   #17
2-4samust
2-4samust's Avatar
I have a second 72 chevy a lwb. Recently my daily driver was hit by a ford
and totaled out a 2003 chevy truck no notes. I had to start driving the old
chevy daily. When it rained water fell right on my left foot and I noticed the
passenger side the same. I have read the replies and tore all that applies apart,I find one part not mentioned. The channel that holds the electricals
for starter engine temp etc held on by 3 5/16 screws need to be pulled and
sealed it has factory sealant inside front on that channel with a seam all the
way across the cowling area. I"ve done that it is suppose to rain here in tx
tomorrow I will find out first hand and post a reply to this one. Before u
mention it I know I could run the water hose. If there is no rain I will.
2-4samust is offline   Reply With Quote
Old 10-29-2014, 11:46 PM   #18
mikey531
mikey531's Avatar
mikey531 is offline   Reply With Quote
Old 10-29-2014, 11:55 PM   #19
Turbo1dr
Turbo1dr's Avatar
Mine has a rust hole behind the glove box. It leaks on top of the AC box and then drips on the floor.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 10-30-2014, 10:23 PM   #20
2-4samust
2-4samust's Avatar
I already have a new core. I will install it before it gets to cold will keep
u posted on progress.
Old 10-31-2014, 09:06 AM   #21
no1udknow
no1udknow's Avatar
Thats what I was going to suggest, does the water smell clean, or like antifreeze? I would suggest just running it inside the garage/shop for a bit out of the rain and see if it is leaking. If not, then you have a seal issue with the oitside world
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-31-2014, 09:13 AM   #22
no1udknow
no1udknow's Avatar
Oh, one other siggestion, is it carpet? If so you may want to look for a small hole in the foor pan, the carpet will wic the water over a larger area making it seemblike its a big leak, when its actually an old screw hole in the floor pan.... seen that befor first hand.
Built not bought!
Old 10-31-2014, 09:15 AM   #23
no1udknow
no1udknow's Avatar
Damnit!! Who revived this 2 year old thread....... I totally fell for it.... wha wha wha
Built not bought!
