Old 10-23-2003, 11:47 PM   #1
billsbowtie
billsbowtie's Avatar
help with sticky gas pedal
i got a new toy 71 chevy the gas pedal is hard to push at frist and the it takes and jumps what is the problem can anyone help thanks bill
billsbowtie is offline   Reply With Quote
Old 10-23-2003, 11:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Take a look at the throttle cable. If anything is bent...replace it.
Actually, I think I would replace it just for general purpose. A stuck throttle can put a crimp in your day...and in your hood.
Old 10-24-2003, 05:00 AM   #3
BadAssChevy502
Yeh It's Fast
BadAssChevy502's Avatar
Arrow replace it
replace it ,they cost less, compare to your life
(I'm sorry if the spelling isn't correct,i'm trying the best I can )
1972 C20 3/4 Pickup Fleetside 502ci Th400
Click here to view pictures of my truck
1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox
"IF IT AIN'T BROKE DON'T TRY TO FIX IT"
Zwijndrecht,
The Netherlands
Europe
BadAssChevy502 is offline   Reply With Quote
Old 10-24-2003, 08:27 AM   #4
jcalisi
Mine was like that as well, but it also had a cruise control built in. At around 50 - 60 the throttle would stick... Come to find out the bushings in my carb was worn out and the shaft was sticking in a few spots.
Just another thing to look for.
Jon
1968 C10 Custom
jcalisi is offline   Reply With Quote
Old 10-24-2003, 06:32 PM   #5
Don Smith
This happend to me after I put 71 style cable in 68 truck. The problem is with plastic housings for the cable at the carb. (one part is attached to carb. fitting and the other is atttached to the grommet that goes through the cable bracket). One part slides into the other and at times they can become slightly seperated and one end of the plastic will grab the front of the other and when you try to accelerate the pedal will be hard and suddeny it will release. I solved mine by using a razor and beveled the housing part that is attached to carb. fitting and put some silicone grease on the lip also.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 10-24-2003, 11:59 PM   #6
billsbowtie
thanks for the info i sounds like don smiths problem it only sticks when staring to give it gas thanks every body bill
i have 67/72 chevy truck parts f/s.
Old 10-25-2003, 08:50 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
I had an old truck that stuck every once and a while. It turned out to be the factory rubber floor matt. After 30 years it had a little pucker right below the gas pedal that would catch the pedal and cause it to act like a stuck throttle. Sometimes it is right there before your eyes.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
