Old 12-02-2012, 11:55 AM   #1
JJAB
Red face 2005 No crank, No start. PLEASE HELP!!!!!!!!!!!!
Gentlemen, I am sure this has been discussed in this forum, but I cant find it and i need immediate help. I have a 2004 GMC Sierra with the 5.3/4L60e. Leading up to the no crank, no start, the truck died on me on three seperate ocassions, but it would crank back up. Then, it died on me as I was backing out of the drive way and then when I pulled in the driveway a day later, it would no longer crank and or start. If/when you put the key in and and try to crank it, the headlights, radio and battery light on the guages come on but that is it. None of the other lights flash or come as normal. Also, when you turn the key to the on position before cranking, the fuel pump is not coming on either. Now, I have replaced ignition switch...no solution. If you cut the lights on and attempt to crank it, the lights do not dim...not a battery issue. At the starter relay, #30 is hot, but #85 is not hot in the key cranking position. I want to think that the problem is in the ignition, but where.
Help me out guys, I do not want to pay for some "ASE GM Mechanic's" Christmas as they trouble shoot my problem over the course of the month of december.
JJAB is offline   Reply With Quote
Old 12-04-2012, 10:06 PM   #2
BlackhillsHD
BlackhillsHD's Avatar
Re: 2005 No crank, No start. PLEASE HELP!!!!!!!!!!!!
ASE GM mechanics are nice guys. I was thinking of helping you out on this until I read that little tid bit.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 12-11-2012, 07:11 PM   #3
RWB-713
RWB-713's Avatar
when your asking for help... might want to leave out the snide remarks about people that could help you....
It sounds like an easy fix honestly, I'd be willing to bet you'd really just be buying that good ol ASE mechanic a meal or two...
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
Old 12-13-2012, 11:47 AM   #4
JJAB
Man Im not sure if you are, were having a bad day or if you are a ASE GM mechanisc, but I wasn't trying to offend you or anyone. You may not want to admit it but, truth is, when you roll your vehicle into any dealership with an electrical problem, you could spend $500 to $1000 bucks fast. Im not ASE certified but an easy fix is a starter or an ignition switch or a ground or positive cable. But , if I offended you or anyone else, I apologize.
Old 12-13-2012, 11:54 AM   #5
BlackhillsHD
There are a lot of dealers out there that give them a bad name. But they can charge that because they have people that are trained for years to work on GM products. Plust they have 10's of thousands of dollars in special tools. Yes I am a GM mechanic and dont like it when people bad mouth dealers in general. I am proud of my level of experiance, and have worked hard to get there.
As for your problem, I know it is very easy when you install the ignition switches to get them off a tooth when sliding them into the housing. For a quick check, I would slide it down out of there and wheel it over by hand. See if when you go full start if it engages that way.
Old 12-13-2012, 01:37 PM   #6
Jdubs71
Jdubs71's Avatar
BANG!!!! Ouch my foot.... Even when you put you foot in your mouth guys on here are still willing to give you a hand. BlackhillsHD I appreciate you guys, lord knows it takes a lot of skill and patients to do what you do.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 12-13-2012, 06:12 PM   #7
JJAB
BlackHillsHD, I appreciate the help. Again, wasn't trying to offend you or anyone else on the site.
Old 12-13-2012, 06:25 PM   #8
64fleetside
I've been there, the mechanic ain't the one gettin rich I guarantee you...
64fleetside is offline   Reply With Quote
Old 12-13-2012, 06:47 PM   #9
JJAB
BlackHillsHD, i here you on your suggestion and I did try that. I found the problem, this may help someone else in the future. I traced it to a bad power source. I ended up disconnected/unbolting the fuse box under the hood. On the bottom of the fuse panel there was a burnt and partially disconnected wire that ran from the ignition inside the truck. There was actually a burnt spot on the bottom of the fuse panel and the wire were partially disconnected. Again thanks!
Old 12-13-2012, 06:52 PM   #10
BlackhillsHD
That would do it. No problem.
Old 12-16-2012, 12:25 PM   #11
Desert1957
Desert1957's Avatar
Glad you found your problem.... I take a lot of pride in my job skills, any GOOD mechanic will tell you our job is not an easy learn.
Not all of us are "Rip Off Artist" we take pride on fixing your vehicle the right way.
Desert
Desert1957 is offline   Reply With Quote
Old 12-16-2012, 05:34 PM   #12
truckdude239
truckdude239's Avatar
Gald you found you problem, Us Ase guys are cool guys, i got 35k in just tools at work not a gm tech but i see a bunch of them
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-20-2012, 10:58 PM   #13
AUSTIN-LM7
well i just had my 99 in the shop ...it would crank and then fire as soon as you let of the key... we replaced the ignition tumbler that worked for three weeks then it started back up..so we took it to the dealership they replaced the key pass sensor Or some sensor close to that name ..haha ...$450 ... i have the old part still if u need any pics or anything..thats if there the same ..shouldnt have changed to much from 99 to an 04
AUSTIN-LM7 is offline   Reply With Quote
Old 12-20-2012, 10:59 PM   #14
AUSTIN-LM7
[QUOTE=AUSTIN-LM7;5769880]well i just had my 99 in the shop ...it would crank and then fire as soon as you let of the key...
crank and as soon as you let off the key it would die...sorry typo
