Old 12-04-2012, 02:50 AM   #1
armybyrd
L99/LT1 Intake?
I was browsing at my local pull-n-pay and saw a 90's Caprice with the L99(4.3 v8). From what Ive read these engines didnt make much power(200hp/245tq) but I also read some had the Lt1 intake manifold. Has anyone swapped one onto a 305 or gen I 350? I know Id need the harness but if its worth it Im sure I could get it for cheap.
armybyrd is offline   Reply With Quote
Old 12-04-2012, 04:48 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: L99/LT1 Intake?
Trying to do fuel injection?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-04-2012, 06:42 AM   #3
TwinTurbo
TwinTurbo's Avatar
Re: L99/LT1 Intake?
Yes, a baby LT1, a 3" stroke 305 block. They do have LT1 intakes on them. You do realize that you have to modify the bolt pattern drill and then epoxy or weld a dizzy mount & hold don and then use external crossovers for the coolant?
TwinTurbo is offline   Reply With Quote
Old 12-04-2012, 02:58 PM   #4
bohmankid
bohmankid's Avatar
Re: L99/LT1 Intake?
Not worth the hassle IMO. You can pick up an entire LT1 with all accessories and wiring harness and put it in your truck for cheap.
bohmankid is offline   Reply With Quote
Old 12-04-2012, 04:12 PM   #5
bnoon
Re: L99/LT1 Intake?
The internal ports are not the same from the "baby" setups, they're smaller. Same modifications apply though.
I've done a few of the conversions for TPI to LT1 intake swaps and they are easy, but from carbed or TBI to LT1 it's going to take a new harness. Score a TPI harness cheap and the rest is pretty easy actually. Here's a site that still hosts some of the write ups that I saw back in the early 2000's when I did mine. http://sethirdgen.org/LT1.htm You can even use the LT4 intake with Vortec heads using the same methods!
EDIT: Oops, looks like most of those links are broken... Dang.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
