Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-04-2012, 03:07 AM   #1
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Broke something in the rear end
I'm guessing it's ring and pinion. The other day when I started to drive Old Yeller the Auburn limited slip started locking up and strange sounds could be heard coming from the rear end. I immediately parked the truck.
Today I pulled the oil fill plug on the rear diff and checked the oil level. It was close to full. Then I took the trany out of gear (posi still locks the axle down when trany is in gear) and rotated the tires and that's when I could hear the clunking. It was noisiest on the right so I pulled the tire off and can push/pull the axle in and out about 3/4 to 1". I didn't have time to pull the rear diff cover.
I suppose it could be the posi unit but given the cost I'm hoping this simply a broken ring and pinion.
Too many hard launches.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 12-05-2012, 01:24 AM   #2
Captainfab
60-66 Nut
Re: Broke something in the rear end
If you can slide the right side axle in and out 3/4-1", you have something wrong in the carrier. You could also have a ring and pinion gear issue, but there is definitely something not right in the carrier.
Old 12-05-2012, 02:02 AM   #3
Old Yeller 1970
DON'T TREAD ON ME
I may be mistaken but I'm pretty sure it was sliding so much because the bearing was completely gone and the posi was sliding back and forth with it. However, I'll double check the carrier and make sure nothing is amiss.
Edit: Didn't realize which thread this was. Sorry for the double. Here's the full story.
Old Yeller
