Junior Member
Replacement gas tank
Any suggestions? I do need it quickly.
I bought a tank from from Classic Parts because it said it was a Blazer/Suburban tank. The ad said the spout may need modifications but I thought that they we meaning if you install it in a truck. My shop says it would need $500 in mods to make it work. I called Classic parts this morning and they we very nice and will allow me to return the item even though it was purchased in March.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: Replacement gas tank
What kind of modifications did the shop say it needed for $500? That seems pretty steep, unless they are talking about cutting the spout, moving it/realigning it, then welding it back up and pressure/leak testing it. That'd be the only way I could see it costing so much.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
#3 | |
Junior Member
I don't know of any new tank that won't need the fill neck modified. The replacement tanks have a short nipple that comes straight out of the tank at a 45 degree angle upwards aimed at a frame mount for a body mount, meaning you can't attach a hose as it will be kinked close. The original fill neck goes forward up and around the obstruction. Take the fill neck(cut it off as close as you can, but fill the old empty tank with water) off your old tank and either have it brazed to the new tank nipple ( you might have to shorten the nipple a little), or use a 2 1/2 - 3 " piece of fuel fill hose and 4 stainless clamps to double clamp splice the nipple to the old fill tube.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
What?
Which one of your trucks is the shop working on? I keep guessing whether it's your PU or Burb
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Junior Member
This is for the burb. I am looking for a direct replacement.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 12-04-2012 at 04:57 PM. Reason: add info |
What?
I got my replacement OE style metal tank from LMC years ago, and it went right in with no modifications.
However the new tank fuel spout is shorter and has no upward bend like the originals, but that didn't pose a problem for me since I just used a little longer fill tube rubber hose (couple inches).
Junior Member
Come on guys anyone know of a direct fit. The one I got from Classic Parts the straps won't even fit.
What?
There is nothing hard about this.
Pick any one of the vendors, and buy the metal OE tank. They all fit right where the original tank was. What was wrong with the straps?
Junior Member
Unless you can tell me one that does'nt need to be modified it is very difficult. I am not doing this my self and the cost to have it modified on top of the cost of thak is not in the budget. I also don't want to be stuck with shipping charges to return another tank. I need to get it right the first time and no one has said they have found a direct replacement.
What?
Probably what is happening is the guy receiving the tank and putting it in is confused with the straps being sent.
All of the vendors I have seen and talked to, ship the straps in a way that makes them look as though they are wrong. The straps need to be bent into shape to work, due to the way the packaging works. Bending them to fit takes no extra effort what so ever, one just uses their hands to bend them into shape. The new straps also use 4 J bolts, where as the originals used 2 J bolts and 2 integrated J bolts. No new holes need to be drilled into the frame.
#12 | |
Junior Member
What?
Well, with out pictures showing what you are working with it is pretty hard to understand what the problem is isn't it.
These tanks are direct replacement, and require little to none modification to replace an original tank of the same size. How many 67-72 Suburbans has this shop done anyways? If they are giving you this much hassle over a fuel tank, I can't even imagine what else they are going to have trouble with.
Junior Member
I have determined it is a Counterpart tank part #69-9310BK1T. Anyone know if you have used this tank?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 12-05-2012 at 05:11 PM. Reason: add info |
#15 |
Might look at this link,this should help you and others.
http://67-72chevytrucks.com/vboard/s...d.php?t=212828
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
#16 |
![]() Join Date: Feb 2011
CrewCab59; That was a great link! Thanks.
MusicMan70 1961 GMC Suburban |
