Old 12-04-2012, 03:45 PM   #1
briank
front clip removal help
Ive tried searching this but it keeps saying fatal error so I'll post it. I'm trying to remove the entire front clip off a 71 c20 in one piece. for those of you who part these and could do this in your sleep, how many bolts total need to be removed and could you tell me exactly which ones need to be removed. I know this has to have been posted before but it won't allow to. Thanks!
briank is offline   Reply With Quote
Old 12-04-2012, 03:58 PM   #2
boynton
boynton's Avatar
Re: front clip removal help
there is a large bolt on the inner fender, the ones at the top of the fender by the door hinge, the ones at the bottom (dont forget about the one right below the rocker-the head is towards the frame) the bolts on the bottom of the inner fender the two core support bolts under the radiator and of course the wiring. the wiring should unbolt from the firewall and then pull away. just becareful to not damage the ends.
Someone feel free to correct/add if i missed anything
boynton is offline   Reply With Quote
Old 12-04-2012, 04:06 PM   #3
67swb72klb
67swb72klb's Avatar
you have to take the cowl off to get to the upper rear bolts for the fenders
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-04-2012, 04:31 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Don't forget to unhook the grounding straps!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-04-2012, 08:21 PM   #5
briank
That doesn't seem too bad, maybe I'll get started tomorrow. Thanks
