12-06-2012, 08:28 AM | #6601 |
Re: What did you do to your truck today?
Getting stuff lined up for water heated manifold plate from Stovebolt. Takes a little plumbing....winter is supposed to arrive Sunday afternoon, so I better hurry!
12-06-2012, 09:06 AM | #6602 |
It fits really well. I did this some time ago and dont recall what I did to make it fit. The LT1 is not running and dont have any brakes. I have the impala SS rear end to install. I have all the wiring labeled. Hope to get back to working on it soon...
12-06-2012, 10:21 AM | #6603 | |
FYI you can buy Duplicolor brand bedliner material by the gallon then roll it on. If you want more texture you can add sand to it. We used it on trailer floors and it worked great. Lots less expensive than paying for rhino liner etc.. |
12-06-2012, 01:33 PM | #6604 |
Finished lowering the 65 yesterday. The rear shocks that came in the kit were too small so I put the originals back on for now. Looks great and the ride isn't bad either.
12-06-2012, 11:57 PM | #6605 |
Too nasty to do much.
I did go upstairs in the shop and organize parts and inspect to get an idea where I stand. Really not all that bad. One fender needs a patch, both door bottoms and both doors have about 6 mirror screw holes. The grill support just needs stripping. Looks like 90% of the work will take place on the cab and the hood. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
12-07-2012, 07:03 AM | #6606 |
Installed new heater blower motor, had to use a mirror to see the holes.
I did not remove the heater box so lining up the blower mounting holes with the Bo was a bit tricky. Took about 20 min. Posted via Mobile Device
People who make excuses didn't want to do it in the first place! http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
12-08-2012, 03:36 PM | #6607 |
All the suspension parts are painted!
Will begin assembly after a couple days of cure time. Pics later today... Steven
12-08-2012, 04:47 PM | #6608 |
I bought a Gearhead 21 Circut 18 fuse universal wiring harness, wires are hot stamped every 6" and are GM color coded. I haven't started wiring my truck with it yet but it looks like a pretty good piece for the money.
Now I can add my power windows, door locks, electric cooling fan, electric fuel pump etc. and have lots of room left over to add even more accesories. It will sure beat the 6 fuse factory fuse block. I'm also looking into adding an ignition switch out of a 1962 Pontiac. That way I'll have an acc. switch position and I've always liked that light up ring that surrounded the old Pontiac ignition switches. |
12-08-2012, 05:06 PM | #6609 |
spent the afternoon rippin out the rotted wood
12-08-2012, 07:41 PM | #6610 |
Here's the pic of the last of the suspension parts:
I'm really happy with the way they turned out. Can't wait to assemble the chassis again. Steven
12-08-2012, 11:29 PM | #6611 |
After 10 years, my drive shaft is finally in ..........
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
12-09-2012, 04:16 PM | #6612 |
Cleaned the engine 3 times with purple clean, a scrub brush and a pressure washer. That was the nastiest engine I have ever seen!
Also used my autozone card to get a free harmonic balancer puller and got it off. Finally, I wire wheeled the engine to get it ready for deburring, a good wipedown with brake cleaner and then paint. I want to set the engine and trans before I wrap up the frame in tarps and start on the body. Steven
12-09-2012, 09:19 PM | #6613 |
Finally got the wiring figured out and every needing power has it. Just have to bleed and adjust brakes and should be insured and registered in 2 weeks. Been waiting for that so I can start driving it and start the next project, a 46 Plymouth. It will be reborn with a SBC power plant.
12-10-2012, 12:43 AM | #6614 |
Filled my antifreeze up after new intake gaskets and ran it for a few to check things out...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
12-10-2012, 02:25 PM | #6615 |
Spent the weekend fitting and installing the wood and tubs... So close!!
12-10-2012, 11:58 PM | #6616 |
Did you use hammered finish paint? Looks good.
65 short step edited by staff |
12-11-2012, 12:12 AM | #6617 |
1 thing at a time is progress.
Finished up my AC/heater hoses for the Vintage Air.
Alan
Philippians 2:14-16 |
12-11-2012, 02:01 AM | #6618 |
Senior Enthusiast
Beautiful work! That looks really nice.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
12-11-2012, 12:26 PM | #6619 |
For Kevin... "65 Custom" 67 Cadillac "Pinecrest Green"
Cheers! Last edited by ChuckW; 12-11-2012 at 12:34 PM. |
12-11-2012, 01:18 PM | #6620 |
Thanks for the pic I really like that color
12-11-2012, 01:27 PM | #6621 |
Yes, hammered black. 3 coats thinned 25% with acetone shot out of a HF HVLP gun at 30 psi.
Thanks! Steven
12-12-2012, 12:56 AM | #6622 |
Alan
12-12-2012, 12:05 PM | #6623 |
I have made some serious progress on my center console/shifter setup. I hope to have it finished this weekend and will add pics to my build thread. Should be kinda cool.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
12-12-2012, 12:12 PM | #6624 |
Might have made a deal for tax time to pickup a 65 swb ss with no engine but very little rot for $750.
I will be using the doors and wheels on my truck and selling the rest. That's the plan but, knowing me, it'll turn into another project. Steven
12-12-2012, 04:46 PM | #6625 |
Tore everything out of the cab to wire wheel the corners and get a better look at the rust damage... Exciting...
1966 Chevy C10 LWB Fleet- Project |
