12-06-2012, 08:42 PM | #1 |
I want to add 2" of lift
I want to lift my 73 Cheyenne 2" since my previous experience was a jeep Cherokee can I build a spring pack or will blocks do the job my truck does not see much off road mostly street time thank you in advance for your help
12-06-2012, 08:59 PM | #2 |
Re: I want to add 2" of lift
2 inch blocks in the back and springs up front will get it done for super cheap.
12-06-2012, 09:23 PM | #3 |
will this change my steering box angle
12-06-2012, 09:47 PM | #4 |
You will not make any adjustments to the steering box. If anything you will just need to get a longer pitman arm. a 2 inch lift will consist of 2 inch blocks in the back, u bolts, hardware, springs for the front, longer pitman arm (if needed).. oh yeah and brake lines and shocks maybe. You could probably get away without lowering the transfer case and not lengthening your driveline with a 2".
12-06-2012, 09:48 PM | #5 |
You can install a lift on these trucks in 8 hours if you have big jack stands, a breaker bar, and a torch.
12-07-2012, 01:31 AM | #6 |
If its a 4x4 skyjacker makes a 2.5 inch lift kit.One thing i would add is a steering box brace the 4x4 trucks are known for cracking the frame around the steering box bolts.
12-09-2012, 07:34 PM | #7 | |
1982 chevy silverado It's all about original guys original let me say again original. |
12-09-2012, 08:14 PM | #8 | |
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
12-10-2012, 04:49 PM | #9 | |
12-10-2012, 05:24 PM | #10 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=442205
Chevy runs in my blood Last edited by zirk; 12-10-2012 at 05:31 PM. |
12-10-2012, 05:34 PM | #11 |
Getting Old; Going Broke
We put the HD coil springs on the front of my 87 R10, brought the front end up pretty much level with the back end. Moog 6454 I think it was. I know when you order front coil springs from O'Reillys you have the option of the HD springs.
Does not get it up as high as a 4x4 I don't think, but levels it out without bringing the rear down like most do.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
12-10-2012, 06:00 PM | #12 | |
12-10-2012, 06:03 PM | #13 | |
12-10-2012, 06:38 PM | #14 |
Has been a few years but it seems they were right about $100 at O'Reillys.
