Old 12-09-2012, 01:47 AM   #1
Bierkan
Bierkan's Avatar
Cleaning Up Floor Rust
My truck has some ratty old carpet with pad in it. Lifting it up today to get a wrench on the body bolts, I discovered it's got quite a bit of surface rust. Probably from years of use and sitting, etc. I want to pull up the carpet, but what process is best to use to clean off the rust? After that I thought I'd prime it for now and later go over it with bed liner stuff.
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
Old 12-09-2012, 10:47 AM   #2
Kim57
Kim57's Avatar
Re: Cleaning Up Floor Rust
If it's just surface rust a wire wheel on an angle grinder should work just fine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-09-2012, 11:28 AM   #3
mknittle
mknittle's Avatar
You are lucky if it is lust surface rust!
most of us arent so lucky.
When you prime it use epoxy or enamel primer lacquer primers don't have mosture protection.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
