12-10-2012, 10:43 AM | #1 |
What type of transmission is this
Need to buy a rebuild kit of my 1964 c10 with 292 engine and three speed transmission
12-10-2012, 11:15 AM | #2 |
Re: What type of transmission is this
That's an early Saginaw 3-speed, non-synchro 1st gear.
12-10-2012, 11:30 AM | #3 |
Do you know where I could find a rebuild kit for this unit?
12-10-2012, 04:07 PM | #4 |
I'm afraid I don't. I replaced mine with a later model Saginaw which is fully synchronized and much beefier. Had to convert to floor shift though, which was fairly expensive.
12-10-2012, 05:19 PM | #5 |
Its not a saginaw. Its a muncie mc318. Should be a non-synchronized 1st gear. Kits are still available through most transmission venders. Found this kit on ebay...just for example. The saginaws had a longer main case and shorter tail shaft. The number of bolts on the side cover are the big "giveaway".
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-11-2012, 06:43 AM | #6 |
Thanks for the help - I sent my pictures to Anaheim Gear and they confirmed the transmission is an early Muncie "light duty" - They have all the parts anyone would need to rebuild yourself or they will do the work for you.
