Old 12-10-2012, 09:49 PM   #1
ah_5500
Beating dead horses
I might be doing just that, but I was thinking, is it possible to flip the front axle on a 48? I'm thinking the axle may get into the oil pan possibly? I'm just getting into messing with this era of truck so I'm a little clueless. Thanks for up any info!
ah_5500 is offline   Reply With Quote
Old 12-10-2012, 10:15 PM   #2
mr48chev
mr48chev's Avatar
Re: Beating dead horses
I'd first jack the truck up and put it on stands under the axle and start measuring. The only truck I've knowingly been around that the axle was flipped on was my buddy Phil Lovejoy's old Ford F-1 Houndog that sat as low as my 48 did with the Camaro stub.
See how much room you have from the top of the spring to the frame and then figure out if you will have enough room under the pan. From looking at the photos of mine it looks like you might have enough clearance to do it. It will be very low though.
My ongoing truck projects:
Old 12-10-2012, 10:21 PM   #3
ah_5500
That is in my list of steps. I am hoping someone will chime in with a more personal experience. Thanks for the input!
Old 12-10-2012, 10:27 PM   #4
mr48chev
mr48chev's Avatar
You should be able to use the bump stops that are already there to prevent the axle from going up far enough to hit the pan if there is room for them to fit between the axle and frame even if you have to cut the rubber down some.
Old 12-10-2012, 10:33 PM   #5
ah_5500
What's your opinion on the steering. It seems like it might be a problem but I'm a little clueless on solid front axle trucks.
Old 12-11-2012, 11:01 AM   #6
mknittle
mknittle's Avatar
I have an Idea but I will have to look at one of our teucks to see if it will work.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-11-2012, 12:46 PM   #7
ah_5500
sounds interesting! is this a steering idea or a flipping the axle idea?
Old 12-15-2012, 12:54 AM   #8
ah_5500
Any new news with the idea?
Old 12-15-2012, 04:04 PM   #9
craig32
I'm confused as to what you mean by 'flipping' the front axle.
craig32 is offline   Reply With Quote
Old 12-15-2012, 10:16 PM   #10
NEWFISHER
NEWFISHER's Avatar
He wants to put the axle on top of the leaf pack. In stock form it rests under the leaves. When you "flip" its configuration to rest on top of the you lower the ride hieght and keep the stock suspension. Similar to flipping the rear axle on those with the axle under the leaves. Like a 4x whenyou add a block it would raise the tire to fender clearence. When you flip the axle to rest on top of the springs, you add a block between the leaf pack and the axle and you reduce the fender to tire clearence.
NEWFISHER is offline   Reply With Quote
Old 12-16-2012, 05:58 AM   #11
craig32
When I changed axles on my truck, the stock axle I put in had blocks on top of the springs. Apparently they WERE between the axle and springs, but someone took them out and put them on top to use the same U-bolts. Every time I hit even the slightest bump they would 'clank' off of the frame. I soon realized they didn't belong there and took them out and bought shorter U-bolts.
SO, I don't know it the axle would hit the oil pan or not, but you will have almost zero travel in your springs and a God-awful noise every time you hit a bump.
