Who makes the best Drag Radial???
Who makes the best Drag Radial? I have an older set of bfg 275/50/15 that I need to replace.
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
Re: Who makes the best Drag Radial???
BFGoodrich and Nitto are up there for the best drag radials.
Registered Truck Offender
I think you should clarify... Best for????
Street duty and some track time thrown in? or Drag Radial class Track only heavy hitter (as in PSCA 275 radial class?)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
mini truck racer
Nitrous or turbo . The M/T pro seems to be the most popular around here at the track .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Having owned a set of nitto's, bfg's and m/t's, my personal experience would be the m/t's over the other two as far as what works at the track.
Nitto's = mileage Bfg's = a middle ground M/t's = faster wear but faster track times Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Thanks guys. Mine are old and tired. Just track duty. It's 60 miles to the nearest track though. I guess Bfg's ought to hold the 450-500 hp i'm expecting.
~Rest In Peace~
M/T sportmans drag radials 31x19x15 with tubes love them
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
![]() Join Date: Oct 2012
The new m/t pro is the best dr out right now but really is a race only tire that happens to have a dot number. They do not make the pro in a 275/50 though,only a 275/60 right now. Lots of local x275 cars 60 footing 1.teens on them. The Hoosier is also a good tire but also not much of a street tire. They also have a much shorter life spam then the m/t. I've personally been 1.19 60' on a Hoosier with my Camaro. The original design m/t is by far the best all around dr. Great traction and pretty good life. I've been running drag radial classes with my car since 2000 and have tons of passes on all the different brands.
Jeff Moyer 65 LWB fleetside 292 4 speed 85 Camaro 436" SBC with a little nitrous 8.12 @ 169 in street trim |
Boosted Member
I wouldn't run anything other than the M/Ts. If you're running a drag radial, you want traction. The nittos suck in my experience. The Mickeys are soft and wear faster, but that's the price of admission if you want to hook on the street.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
For drag racing its Mickeys hands down, i go just as fast with them as i do on slicks. They drive great, just wear out fast.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
The only time i used a Nitto was on a car with 18s, a low profile tire, drove and handled really nice. Never really "hooked" hard, it was a 2000 Camaro with 480 to the wheels.
Sounds like Mickey Thompsons. Thanks fellas.
meowMEOWmeowMEOW
I've got mickeys (dot streets) and I like them, and they've done street duty without a problem if it matters.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
At the body shop.
I have Hoosier's that have foot braked a 1.67 with sbc and 4100# truck
" That didnt make it any newer " " Dont antique the equipment " |
#15 |
Like they said above ,everyone is using the M/T drag radials around here. Looks like the new 275 one is killer.
#16 |
6.0 powered square
Im running nittos on my daily driver, they hook well on the track but i'm only making 350 to wheel, and they cut a 1.85 60ft, my e/t streets best was a 1.90
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
