Old 12-11-2012, 02:30 AM   #1
rudy350
350 manual Trans, swaping to automatic HELP!!!
hey every one.
Well the motor that came with my truck was a 350, did some research and its from a 1969 Corvette 300hp. and it came with a Saginaw 3speed well I took the Trans apart and they ran it with out no gear oil. Well its shot lol.
I was wondering what do I need to make it a automatic?? And what would be the best tranission to use ; it would be a daily driver. Thanks guys
My truck a 1965 gmc . I got donor parts from a 1977 c10 (rear end,& front cmember)
rudy350 is offline   Reply With Quote
Old 12-11-2012, 09:59 AM   #2
kieth
kieth's Avatar
Re: 350 manual Trans, swaping to automatic HELP!!!
Originally Posted by rudy350 View Post
hey every one.
Lots of options, t5, NV3500, NV4500 the t5 has a .80 od ratio, the nv's .73, these would get you the best fuel mileage depending on your rear axle ratio. If you want to go automatic probably a 700r4 would be the least expensive to do. send me this information:
1. rear axle ratio
2. tire diameter (ground to top of rear tire)
3. your email address (pm this to me)
I will send you a spread sheet which shows torque and speeds with your rear
axle ratio for all of the above transmissions and also turbo 350 & 400 trans missiions (direct drive in final gear) Kieth
kieth is offline   Reply With Quote
Old 12-11-2012, 01:50 PM   #3
rudy350
I will Kieth thanks
