Old 12-11-2012, 08:45 PM   #276
RatRod68
RatRod68's Avatar
Re: 72 k20 project
so is an airdog II better than the p-pump swap?
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 12-11-2012, 09:13 PM   #277
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
An air dog is just an aftermarket lift pump, not an injection pump. I do recommend them. You don't really need one below 400hp on a 12v, but the air removal and filtration are a very nice thing. Plus it really helps prime the system versus reaching down to push the stock lift pump. And on a 24v they have the provision for a lift pump, but the cam does not have the lobe on the cam to operate the lift pump. If you install an aftermarket cam, then you can run a 12v lift pump.
Ryan
1969 Chevy milk truck
Old 12-12-2012, 08:18 AM   #278
RatRod68
RatRod68's Avatar
Re: 72 k20 project
So what injection pump does say a 99 24V have? I really wish I knew more about these engines...
build Threads:
Leftovers 68 C20
Semper Fi
Old 12-12-2012, 09:01 AM   #279
ryanroo
ryanroo's Avatar
Re: 72 k20 project
from 89-93 the 12v had the VE pump. its a rotary pump, so when you look at it the injection lines leave the pump in the rear and form a circle.
94-98.5 12v has the P7100 or p-pump. it has all 6 injection lines leaving the top of the pump in a line front to back.
the 98.5-2002 are 24v ISB. they came with the VP44 computer controlled IP. it also has 6 lines coming out of the back in a circle.
beyond 2002 they are common rail systems, meaning all the injectors are fed from on common pressurized fuel rail. the pumps are CP3s and have no means to fire the injectors as that is done by the computer.
im sure there are some variations in the industrial engines i know certain CPL #s have pumps that are not made for accelerator pedal situations. all of the above info is what i know of the dodge truck engines.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-12-2012, 02:28 PM   #280
RatRod68
RatRod68's Avatar
Re: 72 k20 project
ok, so the VP44 is not the lift pump, its the computer itself, got it. I'm going to search on cumminsforum to see if I can find some pictures of where the pumps are located on the engines.
Thank you both so much and sorry for thread jacking
Edit:
I did some more research... I have figured it out now. hahaha. Takes a minute to get the lights on.
build Threads:
Leftovers 68 C20
Semper Fi
Old 12-12-2012, 09:27 PM   #281
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Its the computer and the engine driven high pressure pump. its not known for its power making or reliability. most of the reliability issues stem from poor lift pump performance though. low feed pressure eats them.
no worries, discussion is part of the fun
Edit:
72 K20 12v build
Old 12-12-2012, 09:46 PM   #282
Dieselwrencher
Re: 72 k20 project
Yep Ryan pretty much summed it up. There are A-pump 12v's in industrial apps, some VP30 12v's in ag and industrial stuff, and a very horrible capps system used on 24's up until the CR's, which are common in ag equipment and RV's. That's about it.
Ryan
Old 12-13-2012, 08:20 AM   #283
RatRod68
RatRod68's Avatar
Re: 72 k20 project
ANYWAYS, hows the bowtie?
build Threads:
Leftovers 68 C20
Semper Fi
Old 12-13-2012, 09:04 AM   #284
ryanroo
ryanroo's Avatar
Re: 72 k20 project
mine is just sitting. i ordered a bunch of rust repair panels from Wes, and they should be here in a day or two if i am lucky and early next week if the normal SW CO shipping schedule is held.
Ryan
72 K20 12v build
Old 12-14-2012, 11:03 AM   #285
RatRod68
RatRod68's Avatar
Re: 72 k20 project
Ah. Both of my bowties are sitting too. I got a better cab for the 1 ton, and a 67 clip for the hot rod, along with some kick ass paint, but I have been too wrapped up in building a welding table and my Explorer to mess with either of them.
build Threads:
Leftovers 68 C20
Semper Fi
Old 12-14-2012, 11:15 PM   #286
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i need to make a heavy fab table, but i don't have a lot of room until the green monster is done. then i need to either sell or refurb the parts truck, then i need to think about my trail toy again. the poor jeep has been hidden in the very back and is being fervently ignored. the shame. and i have been eyeballing a wrecked TJ at the JY that i would like to build.
72 K20 12v build
Old 12-15-2012, 12:51 AM   #287
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
I think someone needs to start a back-burner thread!!! I could contribute to that one quite a bit!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-16-2012, 09:46 PM   #288
ryanroo
ryanroo's Avatar
Re: 72 k20 project
did a little hacking today
everything behind it looks pretty good. but i think i have a little suprise behind the cab corner...
Ryan
72 K20 12v build
Old 12-16-2012, 10:57 PM   #289
1972RedNeck
1972RedNeck's Avatar
Re: 72 k20 project
Subscribed
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-17-2012, 09:47 PM   #290
ryanroo
ryanroo's Avatar
Re: 72 k20 project
fed ex brought me boxes today....
i probably need to get the cab off the frame now...
72 K20 12v build
Old 12-21-2012, 07:50 PM   #291
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Got lucky today! for once(i was considering the end of the world theories to be true for minute) the local welding supply stores had what i needed. at the store i usually boycott, i found the feed rolls and tips for my miller. at the store i prefer to use i picked up a 12# roll of .030" the crappy store is a miller dealer, or else i would have gone to my normal place. i am a picky SOB when it comes to wire, so the lincoln store is usually my place anyhow. L-56 is pretty much the best there is, as far as i am concerned.
and on top of all that, blair got my spot weld cutters sent out in time to get them to me for the weekend!
ryan
72 K20 12v build
Old 12-21-2012, 09:12 PM   #292
Dieselwrencher
Re: 72 k20 project
Yeah the Mayans weren't telepathic.
Ryan
Old 12-21-2012, 09:37 PM   #293
ryanroo
ryanroo's Avatar
Re: 72 k20 project
they probably all had a good laugh about it. just a practical joke from the past
72 K20 12v build
Old 12-22-2012, 12:18 AM   #294
ryanroo
ryanroo's Avatar
Re: 72 k20 project
had to test out my new stuff. naturally i forgot i already had the .030 feed rolls. at least i found them before i opened the ones i bought....
i made this patch up since most of the outer floor/inner rocker was in fine shape. there was a few thin spots under the door seal so i decided this was good. i had to employ some trickery to get the radius of the bend right, but that is part of the fun right?
72 K20 12v build
Old 12-22-2012, 07:56 AM   #295
quickman65
Re: 72 k20 project
Just spent last two hours studying your build. Awesome job so far. Never go wrong with a 12V. Good luck.
quickman65 is offline   Reply With Quote
Old 12-22-2012, 07:42 PM   #296
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Looks good! I Had to make a patch like that on my gmc (you can see it in my build), I clamped it to my A-frame which is 2x2 square tubing with nice smooth corners then slowly folded it over the edge with a body hammer until I got it where I needed it.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-22-2012, 07:55 PM   #297
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i wasnt that inventive. i just had to stack material in the pressbrake to get the correct radius. we dont have any big radius punches. most of our customers want tight bends.
i got the patch finished
Ryan
72 K20 12v build
Old 12-23-2012, 08:29 PM   #298
ryanroo
ryanroo's Avatar
Re: 72 k20 project
more destruction
Jacked the cab up and made a little room to work
all just kinda stuck on there. i need another panel i forgot to order for the rear of the cab floor
really got after the drivers side
another poser shot. still need to finish fitting this one. i stayed up late last night and i am all tired so i quit..
72 K20 12v build
Old 12-23-2012, 09:42 PM   #299
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
I love blue masking tape. I have it holding all kinds of stuff to the crew cab!
-Jeremy
Rebuilding an NP205
Old 12-23-2012, 10:38 PM   #300
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i like to make strait cutting lines on weird shapes. at least it gets me close
72 K20 12v build
