Old 12-12-2012, 09:50 PM   #1
66farmer
66farmer's Avatar
My method of hiding engine bay wiring
I wanted to hide as many engine bay wires as I could. As the pictures shows I think I did it. I used gray flex conduit 1" from firewall to core support and 1/2 from firewall to cab support for the rear wiring. In the engine bay picture the charging, starter, cooling and batteries are wired. The gray flex conduit is easy to install I bought it all for aprox $25 from Home depot .
66farmer is offline   Reply With Quote
Old 12-12-2012, 10:43 PM   #2
LDO
LDO's Avatar
Re: My method of hiding engine bay wiring
Very clean. Nice work. Especially like the bulkhead connectors you used.
LDO is offline   Reply With Quote
Old 12-12-2012, 11:26 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Never heard of it before. I like how it looks. Neat and purposeful. Looks neater and more permanent than zip loom.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-13-2012, 12:51 AM   #4
losthope
losthope's Avatar
Very Nice! Generally called "seal tight conduit" At the electrical jobs Ive worked for, used alot for outdoor and wet locations its easier then running and bending "EMT" metal electrical conduit ....Nice job and looks like you found another great use for it!
Seal tight conduit:
http://www.google.com/search?q=seal+...w=1280&bih=640
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 12-13-2012, 01:48 AM   #5
Captainfab
60-66 Nut
Looks great.
I agree, nice use of another non-automotive part.
Old 12-13-2012, 10:39 AM   #6
66farmer
66farmer's Avatar
Thanks , the conduit should work good for me because my truck is not going to be a working truck . Its great to find a different material to use on our trucks that is not an over priced hot rod or classic part.
Someone should start a thread on parts that they have used that are non-automotive.
The only other wiring run that I need to do is for the front turn signals. I'm thinking of pulling the wires through the 1" conduit to the core support area and us a contact strip on top of the core support and on the bottom of the hood so when the hood is closed the power transfers through. I've seen them used in door jams.
Has anyone used them ?
Old 12-13-2012, 10:54 AM   #7
LDO
LDO's Avatar
I have a buddy that installed them in the door jams. They work good but you gotta keep them clean. If your truck isn't going to see alot of the elements, you should be GTG. With a 454 in the truck, I'd have a hard time leaving her in the garage!
Old 05-29-2017, 11:48 PM   #8
graymage
graymage's Avatar
so I stoled your idea I hope you don't mind
graymage is offline   Reply With Quote
Old 05-30-2017, 01:09 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
This is mine. I put in an EZ Wiring 21 circuit harness. Since I used a cable operated throttle cable, I used the original hole where the throttle rod came out from the firewall.
I ran the wires under the headers through a copper tube to shield them. I also ran the headlight harness under the fender wells. I used corvette style spark plug wires that run next to the block under the headers also. The battery was relocated under the bed on the passenger side.
Yes there are wires in there somewhere.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-30-2017, 01:16 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used the stuff on low voltage home wiring all the time and its pretty solid. I'm curious tho, how it holds up to stuff like temperature extremes, elements, chemicals, and vibration.
I like the idea tho, and if it holds up, its a concept worth stealing
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-30-2017, 06:37 AM   #11
graymage
graymage's Avatar
very nice, I like the color
Old 05-30-2017, 06:38 AM   #12
richards72chevy
richards72chevy's Avatar
It looks like the same conduit we use under cattle scales at work.
richards72chevy is offline   Reply With Quote
Old 05-30-2017, 09:07 AM   #13
66farmer
66farmer's Avatar
It has worked out great for me no problems
Old 05-30-2017, 09:15 AM   #14
graymage
graymage's Avatar
Cool thnx I think it's a good idea
Old 05-31-2017, 10:38 PM   #15
luvbowties
luvbowties's Avatar
Thumbs up Re: My method of hiding engine bay wiring
So I like it too. Noticed you even used the 'alike' elbows to terminate the ends into/thru sheet metal. NEATO. Makes a fella want to do a little tidying up under his own ride.
Sam
luvbowties is offline   Reply With Quote
Old 05-31-2017, 11:12 PM   #16
graymage
graymage's Avatar
the last couple days were al about wiring, I also used the stock throttle hole to run my engine wires
Old 06-01-2017, 07:54 PM   #17
WOLFMANmike
WOLFMANmike's Avatar
love it ! great idea for our trucks ... hey brother listen im looking for a cross flow radiator that mounts by brackets welded to the side of the radiator and yours looks like in the pic that how it mounts. and its a cross flow can you please tell me the part number of that radiator and how much it cost you ? it would be a big help brother ... happy truckin
WOLFMANmike is offline   Reply With Quote
Old 06-02-2017, 09:04 AM   #18
Slik66
Slik66's Avatar
Thank you for posting this!! Great idea!
It's what you learn After you know it all that counts!
Slik66 is offline   Reply With Quote
Old 06-02-2017, 01:31 PM   #19
TJ's Chevy
TJ's Chevy's Avatar
Great ideas here
Old 06-02-2017, 10:37 PM   #20
graymage
graymage's Avatar
Originally Posted by TJ's Chevy View Post
Great ideas here
Wring closer dash working
Old 06-02-2017, 11:22 PM   #21
WOLFMANmike
Ok now what gauges is that ... and panel ? That looks great
Old 06-03-2017, 12:14 AM   #22
graymage
graymage's Avatar
Dakota digital and Boese engineering, they cut this insert for Dakota digital gauges
Old 06-03-2017, 02:19 AM   #23
WOLFMANmike
Man they look really good
Old 06-03-2017, 08:07 AM   #24
graymage
graymage's Avatar
thnx wolfman
Old 06-04-2017, 11:27 PM   #25
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
X2.. Nice!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
