Old 12-14-2012, 12:53 AM   #1
Atommik
Atommik's Avatar
Dome light
I've got a 99 suburban that the dome light will not come on when any of the doors are opened. The lights will turn on with the rotary dial on the headlight switch. The "Key in ignition" chime goes on when the drivers door is opened with key in. Is there some kind of relay or something I should look for??
Atommik is offline   Reply With Quote
Old 12-14-2012, 02:36 PM   #2
gmclowsierra
Re: Dome light
Does your light switch have a doon light overide button?
gmclowsierra is offline   Reply With Quote
Old 12-14-2012, 08:00 PM   #3
Atommik
Atommik's Avatar
Re: Dome light
I don't think so, but I certainly will check that out. Thanks.
Old 12-14-2012, 09:31 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
Re: Dome light
That should be an obs. There is a dome override switch on the headlight switch.
95 S_Trucker is offline   Reply With Quote
Old 12-14-2012, 10:36 PM   #5
MadManAndrew
Re: Dome light
If it's a 99-06 it has a button that says "dome override" right by the headlight switch. It's also how you switch from auto to manual headlights.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 12-15-2012, 12:20 AM   #6
Atommik
Atommik's Avatar
Re: Dome light
Well I feel a little dumb now. I've been driving this sub for 3 years and never knew I had an override buton. That did the trick. Thanks everyone for the info and quick answer!!
