Old 12-15-2012, 08:48 PM   #276
Bhelton
Bhelton's Avatar
Re: 1968
Originally Posted by gdavis View Post
Today i presure washed the front cross member and rear end. Monday i an going to wire wheel both parts and then I will sand blast them.. As you can see it is very cold here in Florida. It was in the mid 70"s.
Wished it was like that here. Lucky guy
Bhelton is offline   Reply With Quote
Old 12-16-2012, 01:26 PM   #277
Bomp
Bomp's Avatar
Re: 1968
Freezing
Nice progress.
You are making better use of the mother-in-law room since theres no one occupying it.
Whats the numbers for on your shirt?
Lookin' Good keep it up.
Bomp is offline   Reply With Quote
Old 12-16-2012, 04:47 PM   #278
jonny..2008
Re: 1968
Freezing here too.
You are leading the charmed life there in fla.
i love every machine. even the ones i hate.
Current project (1959) fifty niner gmc fleetside:
http://67-72chevytrucks.com/vboard/s...70#post6514670
MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460
jonny..2008 is offline   Reply With Quote
Old 12-16-2012, 06:58 PM   #279
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Bomp View Post
Freezing
Nice progress.
On the phone= 5=J 3=E 7=S 8=U 7=S=== JESUS call him. People ask me al the time and that gets the door open.
gdavis is offline   Reply With Quote
Old 12-16-2012, 06:59 PM   #280
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by jonny..2008 View Post
Freezing here too.
Maybe in the winter but when summer get here it get real hot.U can't have all the charm life I guess
Old 12-16-2012, 07:05 PM   #281
gdavis
gdavis's Avatar
Re: 1968
I don't remember who gave me the idea of removing the broken bolt in the pinion shaft. But thanks it worked and now I am in business again. I was a little skeptical at first. But I mean to tell you it worked and thanks again.
I did not have a seal pick so I used this small pick which looks like a small ice pick. again thanks.
Old 12-17-2012, 08:47 PM   #282
gdavis
gdavis's Avatar
Re: 1968
Toay, I got a lot done. First, I wire wheeled the rear end. Tried to sand blast but the thing would not work right. So I primed the thing and painted it black.
Old 12-17-2012, 08:51 PM   #283
gdavis
gdavis's Avatar
Re: 1968
Next, I removed the rear end from the 1967 frame. The more I looked at the yellow springs the more I disliked them. So I painted them gloss black also today.
Old 12-17-2012, 08:56 PM   #284
gdavis
gdavis's Avatar
Re: 1968
I pulled the backing plates from the 1972 rear end ad cleaned them up. I also painted them with heat resisting rust-oleum black.
Old 12-17-2012, 09:09 PM   #285
gdavis
gdavis's Avatar
Re: 1968
Next, I used a die grinder and made a x on the ribbits on the rear cross member on the 67 frame. I removed the cross member and installed the one I took off the 1972 frame. Now I can install my brake lines and it will have a good support and the rounting is going to look great. I like the way the 72 brake line are rounted. Thanks BOMP for that idea.
Old 12-17-2012, 10:24 PM   #286
Bhelton
Bhelton's Avatar
Re: 1968
Looking good, nice progress
Old 12-17-2012, 11:36 PM   #287
Bomp
Bomp's Avatar
Re: 1968
Thanks for the credit but I don't think it was me..
I don't even dare to miss a day of not tuning in.
If there's a catagory Im nominating you for the fastest build award.
Old 12-18-2012, 08:14 PM   #288
Xeen
Xeen's Avatar
Re: 1968
That was my idea, but it's ok Bomp can have the credit.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 12-18-2012, 09:16 PM   #289
gdavis
gdavis's Avatar
Re: 1968
Everybody can't have it all. But I am glad it is nice working weather here.
Old 12-18-2012, 09:19 PM   #290
gdavis
gdavis's Avatar
Re: 1968
Sorry about that. So I will thanks you for that IDEA. it really worked,. again thanks
Old 12-18-2012, 09:27 PM   #291
gdavis
gdavis's Avatar
Re: 1968
Today, I got a couple thing finished. One, the rear end off the 1972 frame was mounted on the 1967 frame. Second, I mounted the backing plates back on the 1972 rear end after I blasted and painted them. Third, I wire wheeled the front cross member and sand blasted it and primed and painted the cross member. I am going to start and dismantle the front end tomorrow. I am going to take my time and finish it this week I hope.
Old 12-18-2012, 09:30 PM   #292
gdavis
gdavis's Avatar
Re: 1968
The 1967/1968 frame is getting real dusty setting out under the canophy I think I will buy the sides for the canophy that way I can get ready for paint after the holidays.
Old 12-18-2012, 09:34 PM   #293
gdavis
gdavis's Avatar
Re: 1968
I also will order the outside seals and outer and inter bearings on the rear end and the front yoke seal. The yoke seal is not leaking but I have to change the yoke anyway. It is a little larger and my u clamps are to short. I have the yoke and I might as well change it.
Old 12-18-2012, 10:20 PM   #294
Xeen
Xeen's Avatar
Re: 1968
The speed at which you are making progress is awesome and an inspiration to me and others im sure.
Old 12-18-2012, 11:39 PM   #295
builtbyKane
builtbyKane's Avatar
Re: 1968
Good work, moving along nicely
builtbyKane is offline   Reply With Quote
Old 12-19-2012, 10:27 PM   #296
gdavis
gdavis's Avatar
Re: 1968
anks alot Keen It meansa lot coming from you.
Old 12-19-2012, 10:29 PM   #297
gdavis
gdavis's Avatar
Re: 1968
to I do try.
Old 12-19-2012, 10:39 PM   #298
gdavis
gdavis's Avatar
Re: 1968
Today, I installed the front cross member and the upper a frames. There is a slight difference between th 67 and 72 frame bolt pattern. About 1/32 of a inch for the bolts that screw thru the frame to the welded bnuts on the cross member. But it in in now. I also got the upper and lower ball joints off without a hitch. I am going to call tomorrow and see If I can return them for 72 ball joints if not it is not the end world. That brings a note. I fixed my sand blaster and now it works like it suppose to. I changed the tip to use fine sand. Some fix right. I have a few items that need sand blasted. But tomorrow is another day.
Old 12-20-2012, 09:03 PM   #299
gdavis
gdavis's Avatar
Re: 1968
Today, I had a very good day. I sand blasted and primed and painted.
First i took apart the rotor and backing plate and spendle both of them.
Then I sand blasted them and primed and painted them except the rotor.
I need to send it out to be turned. The rotors and drums for the rear.
Then I sand blasted the hinges. Found one was a little bent so I am going to get another.
Then, I primed and painted the one hinge.
Sand blasted the brake petal assemble and prime and painted it black.
I painted those yellow springs on the front that i did not like, the color Black.
I wire wheeled the rear E-brake cables. They turned out real nice and painted them black.
Old 12-20-2012, 09:06 PM   #300
gdavis
gdavis's Avatar
Re: 1968
more to come
