Old 12-15-2012, 10:46 PM   #1
72 K20
72 K20's Avatar
Harvest special K20 ?
I called about a 72K20 today and the man tells me that it is a rare Harvest special.
I said "it's a what ?"
He said it's a harvest special that was built for farmers,, it has a PTO on the side of the trans that the farmer could run a shaft out the back and bale hay or whatever else might need a PTO. Also, he told me that the front axle was heavy duty for the harvest special truck. From what he was saying it sounds like someone has swapped in a newer single wheel ton front axle. He described the lockouts as being the same size as the center bore of the wheel. When he replaced the front axle wheel bearings he had to get bigger bearings than what was listed for a 72 K20.
I told him that I would have to check into that and that I'd get back to him.
On the cool side it has a fresh 427 in it !!!!
So !! I'm pretty positive that I already know the correct answer but wanted to ask the members here that have more knowledge than I do if this was an actual option or if he has a pieced together truck with a story from the PO !
Take care !
Tom
72 K20 is offline   Reply With Quote
Old 12-15-2012, 11:20 PM   #2
jocko
jocko's Avatar
Re: Harvest special K20 ?
never heard of it, am interested to see what you find out. Am pretty sure the PTO comes off the t-case though, not the trans.
Old 12-15-2012, 11:23 PM   #3
CG
BlahBlahBlah
Sounds like an interesting truck. But the engine would not be original. No 4x4's from 67-72 came with big blocks. I wonder if its a 427 tall deck (truck engine)?
Old 12-15-2012, 11:25 PM   #4
Mister-B
Ask Higgins
Mister-B is offline   Reply With Quote
Old 12-15-2012, 11:29 PM   #5
hugger6933
Does the cast case 4 speed not have a cover on the side to bolt on a pto system? I am not sure about the ones back as far as the ones in this conversation, but the ones I do know of that I built in the 90's had that cover on the 3/4 and 1 tons just for that purpose.
hugger6933 is offline   Reply With Quote
Old 12-15-2012, 11:30 PM   #6
sboris
sboris's Avatar
Hey Tom
Interested. I bought a 70 chassis k20 that had a pto on the side of the 465 also. Had a shaft that ran all the way out the back. My lockouts and front axel seem normal though. Never heard of a harvester special, maybe go look and see if it's on the spid on the glovebox..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 12-15-2012, 11:32 PM   #7
sboris
sboris's Avatar
Mine for sure was on the side of the trans, had linkage that engaged it.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 12-15-2012, 11:36 PM   #8
chipflyer
chipflyer's Avatar
My neighbor had a 72 C30 2WD wrecker with a manual trans and the PTO mounted to the side of the transmission. Never heard of a harvest special either though.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-15-2012, 11:46 PM   #9
jocko
jocko's Avatar
Learn somethin new every day!!! That's 4 of y'all that have seen it (trans PTO), so it must be so! Thanks.
Old 12-16-2012, 12:23 AM   #10
Sicklajoie
The Niner
Sicklajoie's Avatar
Deja vu all over again!
http://67-72chevytrucks.com/vboard/s...hlight=harvest
Funny part is the original poster of this thread and the above thread have almost the same name!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 12-16-2012, 12:33 AM   #11
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
The SM465 has PTO ports on the passenger and drivers side of the case both, the SM420 that was last used in 67 only had a drivers side port. The front axle he describes sounds like the big hub Dana 44 which was the standard axle in the front of K/20s up until about 76, I've heard them described as HD or 1 ton axles because of the size of the hub but the later real 1 ton Dana 60 axle actually had a smaller hub size.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-16-2012, 02:24 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good call!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-16-2012, 02:49 AM   #13
72 K20
72 K20's Avatar
Good call!
I'm asking about a truck that I called about today. I was not aware of anyone else inquiring about this.
I read this forum every day and have learned a lot of things about these old trucks that I did not know even after owning 7 or 8 of them. If it's a problem that I have asked about this, have the mods delete it.
After reading the "other " thread , it doesn't seem to have anything in common with what I asked about other than the name "harvest".
Old 12-16-2012, 10:14 AM   #14
POS1
He was just pointing out the similarities of the two posts.
- Brian
FleetFilter.com
1991 Chevrolet V1500 Suburban 4x4
1986 Jeep CJ7
1969 Porsche 911S Targa
POS1 is offline   Reply With Quote
Old 12-16-2012, 10:56 AM   #15
Sicklajoie
The Niner
Sicklajoie's Avatar
Yep I was. Sorry if it was misunderstood.
Old 12-16-2012, 11:25 AM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
And I appreciated the interesting coincidence, did not intend to ruffle any feathers.
- Mike -
RIP El Jay
Old 12-16-2012, 03:38 PM   #17
SS Tim
SS Tim's Avatar
Agree here with Blazerman's take on things. It is the external vs later HD internal hub styles if you are looking at pictures. Also the NP-205 transfer case on any K20 has a pto port and the earlier T-221 as well. So a '72 four speed K20 would have three pto ports. But a factory fitted pto does sound like a stretch. Dealer installed, sure as well as upfitters for a variety of needs.
If there is a SPID and documentation of any sort I would really like to see it.
SS Tim is offline   Reply With Quote
