Old 12-16-2012, 02:16 PM   #26
Ford Assassin
Ford Assassin's Avatar
Re: Added a TVS 1900 Supercharger to my 5.3 Swap...
I actually have a nitrous kit too, never used it. If I get a wild hair someday, I might 'spray & pray'.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 12-16-2012, 07:51 PM   #27
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
This reminds me of one time I was passed up by a hopped up camaro in my 87 astro van. Little did he know I had a 383 under the hood of it. Not only did I catch up to him right away but I continued to play with him for about 5 miles until he turned off the highway into Eagle River!!! It was friggin hilarious!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-21-2013, 06:37 PM   #28
Ford Assassin
I finally hooked up a boost gauge on Saturday and much to my surprise I am making 10-11 psi when the kit is suppose to be 7 psi on a 5.3 litre.
So I borrowed a SnapOn scope from a buddy and took a look down a spark plug hole. Sure enough, flat top pistons and until at least 2007 no 5.3 had flat top pistons. So it looks like I have a 4.8 afterall.
Still making more than enough power so I am not too upset about it, don't have more than $200 in the long block anyway.
Cable
Old 01-21-2013, 07:51 PM   #29
McNutty
McNutty's Avatar
WOW........ Over 400hp on a stock 4.8 yeah your doing good!!
McNutty is offline   Reply With Quote
Old 06-06-2015, 02:09 PM   #30
1955 mancave
1955 mancave's Avatar
oh boy, I have thought for some time that there has to be some OEM blowers that would work and not cost an arm and leg , if you don't mind when I get started I would love to chat with you , god I love these forums . now I need to start gathering parts, so much fun I'm so excited
thanks
Henry
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 06-16-2015, 01:11 PM   #31
Ford Assassin
Thumbs up Now it's a 6.0 with a Turbo...
Long overdue for an update.....
Sold the blower in July of 2013 and swapped in 6.0 (LQ4) with a custom turbo cam. Pulled the heads for a 3 angle valve job and reassembled with a Brian Tooley double spring kit. Installed LS9 7 layer MLS head gaskets and ProComp head studs. Then built my own turbo setup using a Borg Warner S475 turbo. Using a stock truck intake and rails with FAST 87# injectors the truck puts 690 to the wheels at 14 psi through a 4L80e and a 9.5" 14 bolt (18-20% drivetrain loss).
Cable
Old 06-16-2015, 01:19 PM   #32
Ford Assassin
Talking Pics.....
Figured pics are helpful....
Cable
Old 06-16-2015, 03:01 PM   #33
Houston Ben
Houston Ben's Avatar
690 to the wheels.....damn!
I would be happy with just the supercharger, one of these days!
Houston Ben is offline   Reply With Quote
Old 06-16-2015, 03:21 PM   #34
Ford Assassin
My Monza is almost done too....it will crazy quick for how simple and basic it is.
Cable
Old 06-16-2015, 04:02 PM   #35
tinydb84
tinydb84's Avatar
Nice! No intercooler? Meth or E85? What turbo are you running?
David
Instagram: myfabguy
Old 06-16-2015, 04:14 PM   #36
Ford Assassin
An intercooler wasn't possible without seriously cutting up the front end. The car is running E85 and methanol injection with a progressive controller. The turbo is a T72 Chinese Garrett copy, normally I probably wouldn't run a Chinese turbo, but it was a trade and the whole setup is leftover parts from other projects anyway (except the 80# Siemens flow matched injectors). The turbo is probably only good for 12# before becoming grossly inefficient due to IAT going through the roof. Since I can only fit a 235/60/15 drag radial, I doubt I will be able to put more than 500 to the ground without series traction issues.
Cable
Old 06-17-2015, 04:40 PM   #37
tinydb84
tinydb84's Avatar
Thanks for the info! I am sure that it will hall butt no matter what. I love your blazer btw
David
Instagram: myfabguy
Old 06-23-2015, 05:28 PM   #38
1955 mancave
those are some fun builds so what did you have in $$ in the tvs set up ? and what intake did you use with the blower, any info would be great so thank you.
Old 06-23-2015, 05:44 PM   #39
OutlawDrifter
the tvs becomes the intake with the correct base.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 07-21-2015, 07:53 PM   #40
1955 mancave
thank you
