Bolt on back of oil gauge stuck
I got a new cluster which has better looking gauges than what is currently in my truck. Now, the bolt on the back of the oil gauge is stuck (the one that holds the line in). I've tried PB Blaster and no luck. Maybe a little heat?
Oh and another question, are odometers easily removable? I want to put the odo from the original speedo in the new one. Thanks!
71 K20 64 GMC mud truck |
The Older Generation
Re: Bolt on back of oil gauge stuck
It isn't a bolt it is a brass fitting. Sometimes the are just really tight for a small fitting. It will take a 5/16" wrench to get it loose. I wouldn't use heat on it. It may ruin the gauge. There may be another place to take it apart if you follow the line down by the firewall. You have to be very careful when you take the speedo apart. There is a piece of thin plastic over the numbers and it is very brittle. If you break it the odometer won't work. LockDoc
I tried a 5/16, and when that didn't work, I broke out the vise grips (I know, bad move). It's not really stripped, but more chewed up, I would say
#4 | |
LockDoc
I'd prefer not breaking anything to get to it (yeah right
![]() Any other suggestions?
#6 | |
LockDoc
