Old 12-17-2012, 03:26 PM   #1
4oldcars
4oldcars's Avatar
Hatch handle dis-assembly help please
I'm trying to dis-assemble my hatch handle so I can install a new one and can't get it apart. I have the instructions by LockDoc from last January, but he starts out with the arms piece and spring already removed and that is where I'm stuck. I cannot get the spring and arms piece off the handle shaft. I tapped on it. I tried a puller. It appears to have a "c" clip (retainer), but it ("c" clip) won't move and looks to be part of the rest of it that holds the spring. Does anyone know how to go about this? It must be something simple because it will not go thru the hole in the hatch with this piece on the handle shaft.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 12-17-2012, 05:50 PM   #2
lampltr
Re: Hatch handle dis-assembly help please
Great question as I remember beginning to look into the same issues years ago. Now I have the Blazer back in my possession (After 11 years), I need to begin disassembly.
You happen to know any who rebuilds hatches as well as the handles as you meantion? If I find out anything during my searches, I will PM you, thanks.
lampltr is offline   Reply With Quote
Old 12-18-2012, 10:12 AM   #3
Bentblazer
Bentblazer's Avatar
I'll post up a drawing of a hatch handle, as far as someone to rebuild your hatch you can do that yourself if you have some skills, if did mine myself. i'll post a link to that and you can look it over. http://67-72chevytrucks.com/vboard/s...26#post4550326
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 12-18-2012, 10:54 PM   #4
Dale99
Have same issue. Mine is all rusted up. Trying to take notes here.......
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 12-19-2012, 05:01 PM   #5
4oldcars
4oldcars's Avatar
Thanx bentblazer. I have the parts sheet but it's a little hard to read. I can see I'm missing a couple parts. I have mine completed except the handle. Still need to get the spring and rod(s) bracket off the handle that I acquired so it can be installed. It won't fit thru the hole in the hatch with the bracket and spring on it. And I am missing the bracket that supports the handle shaft. Maybe someone else will chime in here and help me out.
4oldcars
Driving:
The ones I let go:
Old 12-20-2012, 07:43 AM   #6
jaros44sr
jaros44sr's Avatar
Let me know what parts you need, i have a busted hatch here. It might have the parts you need. But, thats only after we determine how to get it apart
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-20-2012, 03:37 PM   #7
Bentblazer
Bentblazer's Avatar
I'm guessing that what you have now looks like the first pic, but still in the bracket. There should be a clip holding it to the bracket, you can see that clip in the second pic.(Lightly rusted looking area above black washer) The handle in the second pic is a garage door handle and the round black washer holds it in place. I used this instead of a cotter key, was just easier. If I remember all you should have to do to remove the handle is remove the cotter key that runs througt the square shaft and handle should pull out, if not it is likely rusted to the cylinder it runs through.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 12-21-2012, 11:11 AM   #8
4oldcars
4oldcars's Avatar
What I'm dealing with is exactly like the first pic. I need to separate the spring and bracket from the handle shaft. The part I need is like in the second pic that holds the shaft it would be the part with two nuts shown holding it in place. jaros44sr, if you have that part, PM paypal payment info - - - and thanx
4oldcars
Driving:
The ones I let go:
Old 12-21-2012, 02:57 PM   #9
jaros44sr
jaros44sr's Avatar
Ok, i see the part you need. No need for payment, if i have it, its yours
Its the bracket, with the 90 degree tang bent on it, right?
Just looked....the bracket is still with hatch, merry christmas!
Soooo, how do you get it apart?
SAFETY FIRST
AS usual, off topic
Jim
Old 12-21-2012, 03:20 PM   #10
Dale99
jaros, there is just a small c-clip that holds the 90deg bracket on it. If it still has the cotter pin in the handle shaft, you likely have to remove it too.
Old 12-21-2012, 04:01 PM   #11
jaros44sr
jaros44sr's Avatar
Thanks for the lead, ill check it out
SAFETY FIRST
AS usual, off topic
Jim
Old 12-21-2012, 06:24 PM   #12
4oldcars
4oldcars's Avatar
Works for me. Let me know if you get it out. That was my original problem - couldn't get the spring off. (my handle with spring is not installed in the hatch)
4oldcars
Driving:
The ones I let go:
