Old 12-18-2012, 02:22 PM   #1
Cheng
Junior Member
Lift Required for 33" Tires on K30?
It is becoming time to put new tires on my K30 and I am considering a slight increase in tire diameter.
Currently my K30 sits on the stock 235/85R16E tires (31.7" Diameter) and is running stock suspension.
I use my truck for towing and hauling so an offroad style lift is not really an option for me; however at many of the jobsites I work at it can get slick and muddy.
I would like to put on 255/85R16E Mud Terrain Tires (33" Diameter) and am hoping some of you may have done the same thing.
I am thinking that by putting on 1" Zero Rate Add A Leafs like these:
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
And also finding a set of the 5/4 ton CUCV Springs for added stiffness in the rear end that I can run these tires without rubbing problems.
Pictures or advice would be most appreciated.
If it wasn't for the last minute, nothing would ever get done.
1953 3800 - SRW C&C Dump - 216/SM420
1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold)
Cheng is offline   Reply With Quote
Old 12-18-2012, 02:37 PM   #2
Cheng
Junior Member
Re: Lift Required for 33" Tires on K30?
This is how the truck sits right now:
Old 12-19-2012, 01:06 PM   #3
junkman8302
junkman8302's Avatar
You should have no problems running the 255/85 tires, although that size seems to be harder and harder to find these days. You may also want to think about a 285/75-16. The 285s should clear without issues, especially if you added the ORD 1" leaves. Nice truck by the way.
"I'm the only John Wayne left in this town" John Rich&Kenny Alphin
96 K1500
99 K1500 Burb (wife's grocery getter)
junkman8302 is offline   Reply With Quote
Old 12-19-2012, 02:19 PM   #4
bohmankid
bohmankid's Avatar
I run 285/75R16 on my truck. It has a 2.5 inch lift. The tires come close, but don't rub. If you can get a tire skinnier than a 285 but still 33" tall, I think you could get away with it with an add-a-leaf. The front is your main concern for rubbing. Cheapest way to raise the front? Small shackles.
bohmankid is offline   Reply With Quote
Old 12-19-2012, 07:44 PM   #5
Your41Plague12
Your41Plague12's Avatar
I ran 285/75/R16's on my K20 with stock suspension and had no issues at all. They didn't rub for me, and with a K30 being even stiffer in the suspension area, I can imagine they will work well for you.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 12-19-2012, 08:07 PM   #6
rustyMUD
You should be fine running the 255/85r16 BFG Mud Terrains on a stock one ton. I have the exact same tire on my 81 GMC K25. It has the HD(8,600 lb gvwr) suspension which currently is sagging a bit due to broken springs from previous owner neglect. I have no rub issues, even at full lock and also flexed off road. I use the truck to haul firewood and have had just shy of 3,000 lbs of logs in the bed with no rubbing issues in the rear, again, that's with the saggy springs. My brother owns an 84 K30 and it has an additional one or two inches of axle to wheel-well height over my 3/4 ton. In summary, you'll be fine with no modifications to the suspension. It's good to see someone else interested in 255/85r16. I'm a big fan of that size, especially on the 73-87 trucks.
rustyMUD is offline   Reply With Quote
Old 12-19-2012, 08:36 PM   #7
Number21
Number21's Avatar
I've got 33s on my '73 K20 at stock height, they fit great - no rubbing.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 12-19-2012, 08:47 PM   #8
cory d
cory d's Avatar
wow 33's at stock height looks dang good. i would do it with pizza cutters, i just like that look
cory d is offline   Reply With Quote
Old 12-19-2012, 10:19 PM   #9
Cheng
Junior Member
Thanks to everyone for the replies and photos.
I really like hearing this first hand information rather than apples to oranges comparisons.
I am going to try to get all the life I can out of the current set of tires, but now at least I have a plan and can start shopping for some deals.
cucv, k30, lift, tires
