12-19-2012, 09:50 PM | #1 |
What rear end?
Can anyone tell me what rear end is in this truck from the SPID?
Posted via Mobile Device Posted via Mobile Device |
12-19-2012, 09:52 PM | #2 |
Re: What rear end?
I may be wrong but to my knowledge no
12-20-2012, 12:21 AM | #3 | ||
"I ain't nobody, dork."
Re: What rear end?
I'm gonna take a swing and say a 12 bolt...
***Unless it's a 3/4 ton... and it might be an Eaton or a Dana*** Gary
12-20-2012, 12:24 AM | #4 |
Re: What rear end?
It's a half ton, and I believe the standard rear end was probably a 3 .73 12 bolt.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
12-20-2012, 12:58 AM | #5 |
70+ ( Old Skool Club )
Re: What rear end?
Unless it shows something specific on the spid, i'm pretty sure big blocks with automatics came with a 3:08 Ratio.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-20-2012, 01:00 AM | #6 |
Re: What rear end?
Will it be an open or limited slip in a BB truck?
12-20-2012, 01:08 AM | #7 | ||
Re: What rear end?
Could be either.
Gary
12-20-2012, 01:22 AM | #8 |
Re: What rear end?
I am 99% sure if the truck came with Limited-Slip Positraction it was an option so it'd be on the spid. Are you sure the original rearvend is in your truck?
12-20-2012, 01:41 AM | #9 |
Re: What rear end?
I'm fairly confident it is the original rear end. I'm considering buying it for parts and to part out. Unfortunately the motor was swapped 20+ years ago. I may go see the truck this weekend.
12-20-2012, 04:23 AM | #10 |
Re: What rear end?
Chevy 3500lb axle (AKA 12 bolt). 3.07 gears with no listed option except open or posi..
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-20-2012, 11:00 AM | #11 |
Re: What rear end?
It appears that it is an open 3.07.Thanks for the info.
12-20-2012, 11:30 AM | #12 |
Re: What rear end?
The SPID on my truck (350/350) doesn't list any particulars about the rear end.
So, from what you guys are saying, it is safe to assume it uses standard eqipment (3.07). However, there is no way the rear end has 3.07 in it. It is wound like a top at 60MPH. It is nearly unbearable. I don't have a tach, but I'd estimate 3500 RPM @ 60 MPH. Any ideas? At what RPM should 3.07 be @ 60 MPH? I might as well just yank the cover and look in the case. It has started dropping oil anyway. |
12-20-2012, 12:22 PM | #13 | |
Re: What rear end?
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
12-20-2012, 02:01 PM | #14 |
Re: What rear end?
Thanks for the input! I am really starting to think that may be a real possibility. I know my grandfather wouldn't have done that when he owned it. But, seeing as my great uncle, the original owner, added saddle tanks and a trans cooler, so he could pull his horse trailers on his ranch, it really make sense. I'll have to grill my grandfather to see what he knows. I really presumed everything was factory (virtually everything else is), because of their traditional "if it aint broke, don't fix it" mentality.
12-20-2012, 02:10 PM | #15 | |
Re: What rear end?
