12-20-2012, 12:51 AM | #1 |
debating and questioning headlights
Blew a headlight on my 70 and now I'm trying to decided whether to stay with the o.e.m style headlights or buy the projection or halo type off eBay and I'm also questioning if it a 5-3/4 or 7in headlight and if a c10 suburban lights fits cause a majority of the vendors info say they're not compatible any advice from anyone that's done a swap like I plan to to or any info to help out
Posted via Mobile Device |
12-20-2012, 01:03 AM | #2 |
Re: debating and questioning headlights
I personally would avoid anything that looks like a Pep Boys Fast and the Furious prom queen car when you turn them on. If they provide good night time lighting, cool. But, if its all blue and weird looking, I think it's a turnoff on these trucks
12-20-2012, 01:10 AM | #3 | |
12-20-2012, 01:34 AM | #4 |
20' Daredevil (Ret)
IMO, it depends if you want better light on the road for better night vision or if you want a trendy look with questionable performance. The relay mod is a great first step for full voltage at the lamps, regardless of which lamps you use.
I'm not sure what you have though.... are you asking whether you have 7" or 5.75" lamps? Just measure the diameter -- also, single lamp (per side) systems like Chevy use 7" lamps, and GMCs with two lamps per side are 5.75". Any 7" lamp, such as from a C10 Sub, will fit any other 7" application. If you're upgrading from OEM, I think the best bang for the buck is a brand-name European E-code, such as Hella, Bosch, or Cibie. Hellas seem to be the most widely available and are also much less expensive than Cibies. They work very well with standard 55/60W H4 bulbs, and overwattage bulbs are also available. Whatever you do, avoid blue bulbs. Not just because of the glare problems towards oncoming drivers, but they light up the road very poorly. Also, be careful with some aftermarket lamps including halo-types -- some are too deep to fit into your truck's headlamp buckets.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-20-2012, 01:40 AM | #5 | |
12-20-2012, 02:14 AM | #6 |
Old member
First is buy the relays and get the wiring all up to date. Then find a nice set of lights. I bought these at the Run to the Sun car show and they have plenty of good light at night. These are 7"
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-20-2012, 02:23 AM | #7 | |
12-20-2012, 02:30 AM | #8 |
Old member
Buy 2 relays 30amps and run a hot wire from battery to relays then cut the head light wires for low beam and high beam. Connect them to the relay then run wires back to head light plugs Ground the relay.
There is a write up in the electrical threads about what all you do.
12-20-2012, 02:47 AM | #9 | |
12-20-2012, 03:03 AM | #10 |
Old member
If you look in the electric threads there is plenty of info on this.
What I stated is just a over view of the whole thing.
12-20-2012, 03:06 AM | #11 |
Yeah I'm going to look more in to the info that thread but or overview has really been helpful thanks for the help
12-20-2012, 03:09 AM | #12 |
Read through this...
http://www.pirate4x4.com/tech/usmcdoc/lights/index.php
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-20-2012, 03:33 AM | #13 | |
12-20-2012, 11:32 AM | #14 |
In my humble opinion, the only way to go is sealed beam halogens and the relay upgrade.
It will be a LONG time before you can't find a stock replacement sealed beam for this vehicle. A rock or burnt bulb is a simple trip to Wal*Mart or parts store away. If you go with some trick aftermarket setup and a rock goes through one, where are you at? The relay thing makes nothing but sense. The factory wiring on these trucks to the headlights goes from the headlight switch, to the dimmer switch on the floor, then to the headlights. What is that? 20 feet or so of wire? 40 years old it is cracked and the connections are green with oxidation. That leads to a higher current draw. Stock, working perfect wiring still only gets you about 10.5 volts at the headlight. Doing the relay upgrade not only gets you 12.x volts straight off the battery, it turned your headlight switch into a headlight relay selector. You'll never have to replace it again. I'm a 28 year veteran of driving GM vehicles of this vintage around. I've replaced TONS of headlight switches. None since I started running the headlights off of relays.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-20-2012, 12:01 PM | #15 |
X 1000 on the relay mod. I'll also toss into the mix to upgrade to an internally regulated alternator while you're at it. That really cleans up the wiring mess these trucks come with. When I did mine I also installed a remote starter solenoid. I think could have filled a 30 gallon trash can with the wire and crap I removed. Here are a couple of wiring diagrams I used. The head light diagram is for a gmc 4 headlight set up but still applies to high beam/low beam. Be sure to use circuit breakers and not a fuse on your head lights. The other schematic is what I came up with when I did my alternator swap (from this site and edited a little). I grabbed my power at that first junction off the back of the alternator instead of running (another) wire from the battery. The last pic is of a bracket I made with relays and circuit breakers. Head lights, electric fan and wipers. Just take your time, think it through and ask lots of questions if needed. It's actually an easy mod and pays off with reliability and bright headlights. Have fun!
Posted via Mobile Device Posted via Mobile Device |
12-20-2012, 12:08 PM | #16 |
67cheby
Check out Delta Tech Lighting, they are the Hid's that i am running in my truck, beautiful light with crystal lenses, they arent cheap and they dont look cheap they look more like stock ones but are extremely bright ! I think right around 300 for the complete setup and you have to do a little modifications to the buckets, here are the mods
12-20-2012, 12:09 PM | #17 |
67cheby
and here is a picture of the lights
12-20-2012, 12:21 PM | #18 |
Hey Mike, did you put your turn signal/park lights in the buckets? That's slick...
12-20-2012, 12:22 PM | #19 |
If you have any salvage yards around you, you can get better relays with water proof connectors for cheap off of many '80's and '90's GM vehicles. I use these for my headlights, since they're made to be in the elements. The ones in the pic are for my fuel pump, A/C clutch and starter, but are the same relays, I just didn't have a picture of the headlight relays handy.
The relays along with a set of Sylvania Silverstar halogen sealed beams work amazing.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-20-2012, 12:23 PM | #20 |
67cheby
i used my stock turn signals, but these do have an extra light in the bottom that you can make turn signals or running lights, i made mine running lights
12-20-2012, 01:52 PM | #21 |
The Older Generation
You might check this thread out too... http://67-72chevytrucks.com/vboard/s...d.php?t=447572 LockDoc
12-20-2012, 05:15 PM | #22 |
Old member
My lights took no mods to install. They are a direct fit in the buckets and have rubber boots over the terminals.
12-20-2012, 08:02 PM | #23 |
12-20-2012, 09:35 PM | #24 |
I'm running cibie's with brighter bulbs.
12-20-2012, 09:51 PM | #25 |
Old member
Post #6 & 7 but I don't have any of the back side. I can get some though.
