Old 12-20-2012, 09:11 PM   #1
dtkarst
Rear motor mount question?
I am trying to order some transmission mounts for my 65 with a crat motor and a standard 4 speed from the factory and had a question..I am replacing the ounts because it was in a wreck and i am doing a frame swap. The bellhousing was broken where it mounts to the cross member and was wondering where i get the mounts for the bellhousing? Its on both sides of the bellhousing where a bolt goes through and hada mount. any help would be great thanks
dtkarst is offline   Reply With Quote
Old 12-20-2012, 09:55 PM   #2
Big Fenders
Re: Rear motor mount question?
Can you forget about the bell housing mounts and just use the side motor mounts and a cross member mount for the transmission?
Tha't what I've done on a few projects.
Bob
Big Fenders is offline   Reply With Quote
Old 12-20-2012, 09:57 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=31
I believe they are called rear engine mounts. You may be able to order these from a parts store like NAPA. I attached a link with a photo if that helps you.
Good Luck
TBONE1964 is offline   Reply With Quote
Old 12-20-2012, 10:03 PM   #4
padresag
Bob
why go through that trouble when you don't have to?
ron
padresag is offline   Reply With Quote
Old 12-20-2012, 10:19 PM   #5
luvbowties
luvbowties's Avatar
Smile Re: Rear motor mount question?
Like Tbone said, Napa, Advance A/P, AutoZone, O'reilly's, Rock Auto, CarQuest, etc--get 'em local--save shipping.
sam
luvbowties is offline   Reply With Quote
