Old 12-20-2012, 11:02 PM   #26
cubber
Re: Air bag installation
Oh, yeah, I also have the adjustable trac bar, lol. Few more pics
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 12-20-2012, 11:20 PM   #27
shawno72
C/10 junkie
shawno72's Avatar
Loos good cubber. What brand of trailing arms are those?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-20-2012, 11:31 PM   #28
cubber
I got them from Classic Parts. They were like $50 more than a set of the stock type. I had a 72, and the arms on it were rusted through. Before I sold it, I swapped the trailing arms (and all the other good 5 lug, disc brake,power steering type pieces,lol).
=MATTHEW
Old 12-21-2012, 12:20 AM   #29
shawno72
C/10 junkie
shawno72's Avatar
Good deal. Sounds like you got all the good stuff
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 12:32 AM   #30
cubber
Yeah. I will be following your decision, and I have noticed that you are a lot of help to lots of people on here. If you have any questions about e products or install, feel free to pm me, because I would be honored to help you in any way I could.
=MATTHEW
Old 12-21-2012, 04:40 AM   #31
bk2life
your front is super easy to bag. do you have speindles already? can you weld/cut steel? i can walk you through step by step. it really only costs about 250 dollars to bag the front of a chevy. (air bags are around 89 dollars each)
of course this is no compresser/valves, just bags and gettin them in there, making your truck go up and down.
bk2life is offline   Reply With Quote
Old 12-21-2012, 04:54 AM   #32
shawno72
C/10 junkie
shawno72's Avatar
H
Thanks man I appreciate the kind words. It will be a while before I do the install. I'll start gathering parts soon though.
Yeah I got some fab skills. Used to work for Cozad Trailers building heavy haul trailers and was an iron worker for years so I is a certified welder as well All I need is some measurements and what thicknesses for the steel and I can def make the pieces up. Could get some widths and measurements for hole placement and the such?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 05:44 AM   #33
bk2life
i use no cups, i trim the upper spring mount up about an inch, and then a 2.5 pipe in the bttom control arm. i cna get you some better pics, but it might take an extra day being im in afghan, and truck is in phx..
Old 12-21-2012, 08:32 AM   #34
shawno72
C/10 junkie
shawno72's Avatar
If you could post more pics that would be great. No rush as I won't be bagging it for a few months.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 09:23 AM   #35
cubber
He's right, it would be super easy to make your own stuff, especially for a "certified welder", lol. All you would really need is your bags and some plating, and a piece of pipe. You just have to decide how much you are willing to cut and modify your stock pieces. I could unbolt my upper plates, pull the bags and go back with stock springs if I wanted, but mine won't go as low as some. If you can come up with a set of a arms (lower) you could cut them, and install your pipe, and just swap out when you're ready. I just didn't want to cut mine because I didn't know if I would like the bags or not, but the lower bag cups that come with the PB kit are pretty low, lower than some of the ones that people have to cut down.
=MATTHEW
Old 12-21-2012, 10:55 AM   #36
shawno72
C/10 junkie
shawno72's Avatar
Will the front crossmember sit on the ground aired out with no bump stops and the PB lower bag cups installed?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 11:28 AM   #37
SCOTI
SCOTI's Avatar
Depending on the OD of the front tire & if it has dropped spindles, yep.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-21-2012, 11:39 AM   #38
shawno72
C/10 junkie
shawno72's Avatar
I have dropped spindles and will be running P215/70R15 tires.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 11:45 AM   #39
CC69Rat
CC69Rat's Avatar
Lay it out!
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-21-2012, 11:54 AM   #40
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by CC69Rat View Post
Lay it out!
I'm working on it
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 12:47 PM   #41
SCOTI
SCOTI's Avatar
That's 26.85" tall for front rollers & should put the a-arm bushing pivot points on the dirt.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2012, 12:48 PM   #42
shawno72
C/10 junkie
shawno72's Avatar
That's what I am looking for
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 08:25 PM   #43
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Thats the same size tire I'm running on my '67 with McGaughy's drop spindles and you can see where the arms are hitting the deck here. You wouldn't be able to fit a cigarette under the crossmember here either. Plus, the tires hit the inner fender wells about the same time.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 12-21-2012, 08:26 PM   #44
shawno72
C/10 junkie
shawno72's Avatar
Looks great Steve, any more pics of your truck and or install?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 08:43 PM   #45
stevencvn72
Kill Bill...et
It's not too pretty, but it's a driver, and I built it myself....and after seeing these, I see my photography skills are about as good as my truck building skills.....LACKING.
-Steve
I Grease
'67 Chev stepper
Old 12-21-2012, 08:57 PM   #46
shawno72
C/10 junkie
shawno72's Avatar
I see no problems with your build, looks great to me
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-21-2012, 10:32 PM   #47
cubber
Shawno, these guys are tellin' the truth. My Contol arms are stock, I have 2.5" McGaughy spindles and a 29" tall tire. If I had a similar size, my bushings would be real close. HMMM, I think I have a set of 215's, with skinny whitewalls on the carhat the engine blew in on my way home from SoKY Classics tonight.
Steve, I really like your truck, brother!
=MATTHEW
Old 12-21-2012, 10:57 PM   #48
firedog
firedog's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=335590
here is a thread from when i bagged my truck, most parts were picked up from craigslist after studing the info from here.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 12-22-2012, 12:23 AM   #49
shawno72
C/10 junkie
shawno72's Avatar
Thanks firedog. There is some useful tips I will be using.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-24-2012, 07:16 AM   #50
bk2life
id love to post more, but im in afghan, and wont be home for a couple of months.. the fronts are super easy, i can walk you through it -step-by-step
