Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-15-2012, 07:28 PM   #176
pickup67man
pickup67man's Avatar
Re: Project Family Hauler
Working on matching the body curve on the door with the curve on the suburban. They are close but not exact. I used the rear part of a drivers door to make the rear of the door but as I keep finding out suburbans are different. Now is the time to make it work. The top part of the door was in too far so I made the body match, the middle of the door was flatter so I cut the suburban skin so I could flatten it.
The bottom of the door lines up with the rocker panel but was rusted out on the suburban all the way to the wheel well. I finally opened up the body cavity (yes I did a body cavity search), looking for rust.
Then the worst thing happened, my welder stopped welding. I know I was almost out of gas, so I checked my wire spool and it was empty. I looked at the time and the welding supply store had been closed for 15 minutes.
Done for the weekend!!!
Wrong, if the rain quits I can cut out a patch panel from extra parts. I don't like taking electric tools out in rain storms (reason for new garage).
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 12-15-2012, 09:53 PM   #177
jbclassix
Junk Yartist
jbclassix's Avatar
Wow! I have less inner wheel well than you do! That doesn't look too bad!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-15-2012, 10:29 PM   #178
pickup67man
I was really surprised too. The way the outside looked and I know how much dirt came out of that cavity. It was full of dirt up to the inspection plug in the wheel well (plug was missing).
Travis
Old 12-15-2012, 10:49 PM   #179
pickup67man
Well anyone from Washington or somewhere close will understand this. It quit raining and was only a drizzle so I ran my extension cord to my pile of parts and cut off a patch panel from an old bedside.
I cut and fit the panel. Suburbans have a spot where the floor is spot welded to the skin and I thought it was good. So I cut there and the splice will be supported by the floor. It goes up high because there was a dent at a bad spot. See the arrow.
Then I finished cleaning the back of the patch and the inner wheel well with POR 15 clean and prep. I will paint it tomorrow. Got nothing else to do.
Here is the saddest site this weekend.
No more wire.
And almost no gas.
Travis
Old 12-16-2012, 12:29 PM   #180
jbclassix
Junk Yartist
jbclassix's Avatar
Lookin really good man! I hear ya on the consumables!
-Jeremy
Rebuilding an NP205
Old 12-21-2012, 01:51 AM   #181
Yerboogieman
Yerboogieman's Avatar
I know how it is. I was trying to get as much work done on my Suburban as possible when it started raining. I did get the mufflers on during the hale storm though. The cops weren't liking the open headers much and it drew a lot of attention.
If you're ever down in Orting, I work at Safeway. Stop by, you'll probably see my Suburban out in the parking lot. I work mornings.
-Taylor
1971 Chevy Suburban 4x4 Build Thread
Yerboogieman is offline   Reply With Quote
Old 12-21-2012, 10:59 PM   #182
pickup67man
You probably have seen my finished 67 Chev. I've had it at the Kingsman show in June for around 10 years.
It rained so much yesterday I had a moat around my garage. Glad I raised it a foot above high tide here in the valley.
Travis
Old 12-22-2012, 02:45 AM   #183
Yerboogieman
The only one I saw this last June was this one. I was probably working during the Kingsman show.
-Taylor
Old 12-24-2012, 05:42 PM   #184
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work! I was thinking on the front door body line not matching up when using it for a rear door. My solution was to maybe cut up a long bed bed side to try to use as an outer skin. IDK if it'll work or not? Maybe I'll get to my crew cab project this year. It's looking very unlikely though. I have to get the Longhorn drivable first. Haha By the way, I hope you and your family have a Very Merry Christmas!!!!!
Ryan
1969 Chevy milk truck
Old 12-24-2012, 06:26 PM   #185
pickup67man
This is my other truck.
Travis
Old 12-24-2012, 06:34 PM   #186
pickup67man
Don't know if that would help. The suburban could still be different after that. I'm just going to blend it back to the wheel opening. I'm basing the body line difference on the door jamb from the truck cab. It matches my new door but slightly different than suburban skin. My cut was less than 3/16" and still have 1/16" gap to weld. That was enough to match bodyline.
Travis
Old 01-06-2013, 10:44 PM   #187
pickup67man
After all my welding and grinding I found my new garage needed some airflow. The smoke and dust were landing on everything so I put a fan in the ceiling. It vents out the roof. Now when I recoup from Christmas I will get more gas and wire for my welder and will see how much the fan helps.
Travis
Old 03-24-2013, 11:23 PM   #188
pickup67man
I'm back. Been working on the other truck so I had a break.
Replaced all my old braided fuel line, it was 14 years old and my garage smelled like gas all the time. Plumbed it for a return style system. Used teflon lined braided line this time with steel hardline in the frame. Much easier to work with. This should fix my vapor locking problem too.
Took some boards out of my bed to access the fuel line.
Then put the bed wood back together.
Then I get back to the suburban.
Painted inside before welding patch panel.
Patch welded in and smoothed. Also replaced the door skin again.
Did a little massaging of the latch and the door closes with just a click now.
Happier with the door skin now. It fits the curve better, the top is even with the inside and there is no bulge in the middle.
Started setting the door gaps.
Bottom door gap is 1/8"
Rear door gap still needs some work. But getting closer.
Travis
Old 03-24-2013, 11:28 PM   #189
pickup67man
Travis
Old 03-25-2013, 12:27 AM   #190
jbclassix
Junk Yartist
jbclassix's Avatar
Wow... I was just wondering how your 4 door was coming! Looking good!
-Jeremy
Rebuilding an NP205
Old 03-25-2013, 01:14 AM   #191
pickup67man
Thanks. Let me tell you I'm not going to make a career out of this and won't do it again. Too many curves to get lined up.
Travis
Old 06-09-2013, 09:51 PM   #192
pickup67man
Well I made progress this weekend. (well a few other weekends too). Got most of the rough bodywork taken care of and sprayed some primer surfacer on the doors to see how they look.
Travis
Old 06-09-2013, 10:00 PM   #193
jbclassix
Junk Yartist
jbclassix's Avatar
Sure looks straight to me!
-Jeremy
Rebuilding an NP205
Old 07-16-2013, 03:21 AM   #194
Frizzle Fry
Frizzle Fry's Avatar
Sweet!
Frizzle Fry is offline   Reply With Quote
Old 07-16-2013, 11:13 PM   #195
pickup67man
Originally Posted by Frizzle Fry View Post
Sweet!
Travis
Old 08-22-2013, 09:27 PM   #196
swamp rat
swamp rat's Avatar
Thats looking great! keep up the pace and it will be a family hauler sooner than ya know it!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-16-2013, 11:27 PM   #197
pickup67man
I did get it turned around in the garage. Pretty easy when it's on roller skates.
I am making a patch panel list for the rainy season.
Travis
Old 09-16-2013, 11:31 PM   #198
pickup67man
Now for the ADD of my life. Going to help my dad on some rust repair on his quirky project. 1961 Corvair Lakewood wagon.
Travis
Old 09-16-2013, 11:49 PM   #199
swamp rat
swamp rat's Avatar
Welcome back!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-08-2013, 06:13 PM   #200
Cameron 1137
Cameron 1137's Avatar
Awesome lakewood!
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
