Old 12-22-2012, 01:24 PM   #1
jks67ss396
newbie question. 6lug->5lug, axle swap?
Hi guys
Im new to these trucks.
have a fresh 3.08 5lug rear end, but need to go to 3.73.
found a few 6 lug rears on craigslist. but i need the 5 lug....
could i just swap my 5 lug axles into the new 6 lug rear end and put those 6 lugs into my 3.08 rear and sell it?
thanks
jks67ss396 is offline   Reply With Quote
Old 12-23-2012, 02:05 PM   #2
jks67ss396
Re: newbie question. 6lug->5lug, axle swap?
bump
thanks guys
Old 12-23-2012, 02:26 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What year rearend?
Keith
Convert to disc brakes.
Old 12-23-2012, 02:32 PM   #4
jks67ss396
71
Old 12-23-2012, 02:42 PM   #5
lolife99
lolife99's Avatar
The only 67-72 oem 6-lug rearend that will directly swap your 71 axles,... is the 1970 6-lug rearend.
(I assume you have coil springs,... and not leaf springs)
But there were two widths of rearends in the 1970 model year.
Some were the width of the earlier 67-69 trucks, which is narrower.
You will have to measure to be sure.
The 71-81 4x4 trucks had 6-lug rearends, but they were set up for leaf springs.
These rearend will allow you to swap your 5-lug axles,... but the brackets will be wrong.
Keith
Old 12-23-2012, 03:18 PM   #6
jks67ss396
oh, i thought you meant what year is mine... mine is a 71, coil.. but im not sure what year his is.
but thats good to know. i would have never guessed that the widths were different from 67-72
by chance were the diff housings date stamped???
Old 12-23-2012, 03:45 PM   #7
lolife99
lolife99's Avatar
I don't know about the date stamp.
Just measure your 71 rearend.
The other rearend will have to be the same width.
The 71-72 (and late 1970) rearend is approximately 1-1/2" wider than the 67-69 rearend housing.
There are a TON of threads on here about this same question.
Do a google search at the top of the page.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
Keith
