12-23-2012, 04:12 PM | #1 |
Saginaw speedo Gear
So I did all the calculatin' and figured out what driven gear i'll need matched to my tire size and gear ratio.
Really looking forward to fixing my speedo since it plays hell on my OCD. Get the gear in and try to install.... The old gear 'bullet' is longer than the regular ones I'm used to so the gear I ordered won't work. Never even knew there were different bullet lengths.. Need a new bullet! back to the old drawing board....
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
02-12-2013, 02:14 AM | #2 |
Re: Saginaw speedo Gear
interesting.....i am also trying to fix my speedo and when fingering my transmission it seemed the gear inside the trans is closer than where the "bullet" puts the speedometer gear(hope that makes sense).......hhhmmmm
please post your findings |
02-12-2013, 08:44 AM | #3 | |
Bad News: Speedo is still off from my GPS reading so it appears I would need to change the 'drive' gear which is the one on the shaft. In your case, your drive gear may have come off the shaft and slid down. There should be a retaining ring to prevent that but you know how that goes. Are you working with a saginaw trans as well?
02-12-2013, 11:07 AM | #4 |
Easier ways to get it right. Ratio adaptors!!
http://www.transmissioncenter.net/sp...____va.htm#350 |
02-12-2013, 11:14 AM | #5 | |
