Old 12-23-2012, 10:47 PM   #701
jmedero
jmedero's Avatar
Re: 68 S/C update.....
Nice.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 12-24-2012, 08:08 AM   #702
EZ SPEED
EZ SPEED's Avatar
Originally Posted by Hart_Rod View Post
**** Thanks!!! ****
Thanks for the info! I'll hit you up with some more questions later.
*** UPDATES!! ***
Picked up a nice steering wheel to match my Billet Specialty wheels (thanks JWALL!!!) Also, the first motor I was looking at didn't work out (long story......can some please delete those pictures???), so I've tracked down two other candidates:
1st: L76/6L90E out of an 09 G8 with 16K miles.
2nd: L99/6L90E out of a 11 Chevy truck with only 900 miles!!
Any thoughts to which one might be better for running the TVS1900 Magnacharger???
Love the steering wheel, looks great.
Just remember if you buy one of those, they will most likely have AFM (Active Fuel Management) which turns off cylinders to conserve fuel. It does this by the lifters...so if you decicde to put in a nice rumpity cam...you will have to change out all the lifters, lifter buckets, cam sprocket, upper plate (under intake) and pushrods.
Not sure if either one of those has VVT (variable valve timing), in which you will have to change out a few more pieces like the timing cover and a couple of other small pieces if I remember correctly, to do a the bumping cam also.
Just do a little research before you buy and hollar a me if you have any questions.
Eric
1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509
2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq
2016 Camaro SS - Satin Pearl Nero wrap
My 2010 Camaro SS Magazine feature (SOLD)
http://www.superchevy.com/features/g...of-perfection/
EZ SPEED is offline   Reply With Quote
Old 12-24-2012, 09:53 AM   #703
Hart_Rod
Hart_Rod's Avatar
Is there a bigger factory cam (Corvette??) that will work with VVT or AFM? Should I just leave the motor stock and add the supercharger and take it as is? Is the iron block preferable over the aluminum G8 block? PM me your phone number when you get a chance, I would like to discuss this more.
Hart_Rod is offline   Reply With Quote
Old 12-24-2012, 10:37 AM   #704
EZ SPEED
EZ SPEED's Avatar
The LS9 cam is a great factory cam. works well with superchargers and turbos. no lope. But it doesnt work with VVT or AFM.
I would probably do the G8 engine if it was me. Some guys really love the iron block, but its not really necessary. look at my SS..aluminum 6.2 block bored and stroked to 427 cubes and mine makes 896 flywheel horsepower
You can always run the stock G8 with the supercharger for now....then later on swap out the cam and respective parts.
Eric
Old 01-07-2013, 12:09 AM   #705
Hart_Rod
Hart_Rod's Avatar
I hit the road at 3AM this morning and got back around 6PM, nearly 800 miles and very long day but I now have the new powerplant for the Farm truck. Feast your eyes!!!
2013 Camaro SS 6.2/6L80E with ....1....3.....5...miles!!!!
Old 01-07-2013, 12:17 AM   #706
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Dude, that's averaging 53 mph after stops for fuel, lunch and load.
Can't blame ya for getting there before missing out.
Posted via Telegraph
Zoomin is offline   Reply With Quote
Old 01-07-2013, 12:24 AM   #707
gringoloco
A guy with a truck
gringoloco's Avatar
That's what I'm talkin' 'bout! It's getting the blower from Steiny?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-07-2013, 07:51 AM   #708
emilio impala
emilio impala's Avatar
Es hermoso ese motor!
emilio impala is offline   Reply With Quote
Old 01-07-2013, 07:53 AM   #709
EZ SPEED
EZ SPEED's Avatar
Awesome!! congrats!!
Eric
Old 01-07-2013, 08:13 AM   #710
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Dang bet the oil. Never even got checked before she was pulled
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-07-2013, 08:20 AM   #711
Xeen
Xeen's Avatar
Wow what a great score, you are a lucky man, did you get the computer and wiring harness with it?
Also is that one where the computer requires the cluster/information display center to work correctly?
I guess I'm just wondering whats it takes to put one of these in a c10 and work correctly.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-07-2013, 09:30 AM   #712
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
So so so jealous! LOL. Great score buddy!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-07-2013, 09:42 AM   #713
Rusbuilt
Rusbuilt's Avatar
That...is...AWESOME!!
Rusbuilt is offline   Reply With Quote
Old 01-07-2013, 09:48 AM   #714
sourkraut
sourkraut's Avatar
Awesome
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 01-07-2013, 10:38 AM   #715
Hart_Rod
Hart_Rod's Avatar
, there was a 3 hour break in the middle.
Yes sir! It's sitting in the back of my truck, .
Thanks!
Thanks!
Thanks!
I got the complete engine/tranny, all accessories, computer, electric pedal and wiring harnes. I'm not sure about the cluster. I talked to John at Speartech and he's going to build me a custom harness for it.
Thanks!
Thanks!
Originally Posted by sourkraut View Post
Awesome
Thanks!
Old 01-07-2013, 02:09 PM   #716
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Holy cow, nice buy Rob!
That must have been once heck of a test drive for that '13 Camaro.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-08-2013, 12:12 AM   #717
Number98
Prestige Worldwide
Number98's Avatar
I hate you....
Number98 is offline   Reply With Quote
Old 01-08-2013, 12:36 AM   #718
Hybridcx
Hybridcx's Avatar
I might have missed it and I am going back a few pages here but did you ever "tune" your fuel filler in the marker light? Id be interested to see how that turned out. Love your truck
Hybridcx is offline   Reply With Quote
Old 01-08-2013, 12:43 AM   #719
Hybridcx
Hybridcx's Avatar
Never mind I just stumbled across this...
http://67-72chevytrucks.com/vboard/s...d.php?t=380571
My bad.
Old 01-08-2013, 02:13 AM   #720
jrdv
jrdv's Avatar
Very nice!!!
I think you made the right choice!
Be sure to post every little detail so I can copy what you do ( minus the SC of course )!
John
jrdv is offline   Reply With Quote
Old 01-08-2013, 09:46 AM   #721
killer71
killer71's Avatar
Wish I could afford something like this!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 01-08-2013, 09:57 AM   #722
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I think the supercharger is supposed to be in the front...
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-08-2013, 10:10 AM   #723
Hart_Rod
Hart_Rod's Avatar
, it was a blast!!
Originally Posted by Number98 View Post
I hate you....
, PM sent.
My bad.
Thanks and glad you found it!
, it was your thread that got me looking for this.....
No wonder I could only get 400HP out of it......
Originally Posted by jrdv View Post
Very nice!!!
John
I think we need to work together on this. Here's my parts list so far:
Dirty Dingo adjustable engine mounts, CPP engine stands, CPP tubular tranny crossmember, auto high hump, Speartech harness, factory accessories, Doug Thorley big tube headers (hopefully)....
I think you will have to switch your oil pant to either an Fbody (won't work with the ECE mounts) or the Cadillac CTsV. Add as necessary.
Old 01-08-2013, 11:33 AM   #724
67cheby
67cheby
67cheby's Avatar
WOW...sweet POWER PLANT !
67cheby is offline   Reply With Quote
Old 01-08-2013, 12:03 PM   #725
Zoomin
Man of Mini-Talents
Zoomin's Avatar
It sure is!
Square Peg sure would look cool with this for sure. Heck, anything would.
