Old 12-24-2012, 10:05 AM   #1
Realnoisy
Realnoisy's Avatar
Shortening Control Arms for Narrowing Track
There is very little information on shortening the stock upper and lower control arms to narrow the track. I know they did this old school and would like to see photos of C10's with this modification. I have read about removing 1.5 out of the upper and lower to achieve the narrow track. I currently have a 65' C10 LWB with '73 C10 1.5 sectioned xmember, bagged with 2.5 spindles. I'm just curious of how this done so any photos of the type jig used, links to modification, or any input would be appreciated. I know I could buy arms and dropped members from vendors to achieve a narrower track but I'd like know more about this modification.
Realnoisy is offline   Reply With Quote
Old 12-24-2012, 10:42 AM   #2
SCOTI
SCOTI's Avatar
Re: Shortening Control Arms for Narrowing Track
I know about sectioning the lowers to pull them in but not the uppers (typically narrowing the lowers requires fewer shims for the uppers thus pulling them in).
Mine had the lower BJ cut out as a square section, removed the amount of material that the BJ needed to be moved inboard, & then re-welded together. The bump-stop is removed of course & the a-arm lip is trimmed significantly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-24-2012, 10:53 AM   #3
Realnoisy
Realnoisy's Avatar
Scoti, any mods to the tie-rod ends after doing this?
Old 12-24-2012, 12:58 PM   #4
stefan
New Member
Thats what i was wonering im interested in buying pb narrow arms and to move the wheel forward but what about the ty rod assembly or sway bar being narrowed,i guess i need to call Nathan at Portbuilt.
stefan is offline   Reply With Quote
Old 12-24-2012, 01:42 PM   #5
SCOTI
SCOTI's Avatar
There's enough thread on the tie-rods that they can be trimmed accordingly. You will have less total adjustment in the end.
The sway bar will require trimming. But, this is already true when doing bags in these trucks anyway. The bracket that mounts to the a-arm will possibly interfere depending on the set-up. Aftermarket bags w/end links vs the fixed bushing mount might work better but would be trial & error as for what will work the best.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-24-2012, 03:10 PM   #6
Realnoisy
Realnoisy's Avatar
This was posted by lowestsixty7 and are the only photos I can find on the site. I'd like to see what they look like mounted.
Old 12-24-2012, 03:50 PM   #7
SCOTI
SCOTI's Avatar
Basically, I have a set of lowers that were cut on the yellow line.
The material between the yellow & red lines was removed
The BJ section was moved inboard & then it was welded back together.
The lip was trimmed back to the shock mount & blended. The front lip was done a similar amount....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-24-2012, 04:07 PM   #8
Realnoisy
Realnoisy's Avatar
Very cool Scoti! I was wondering what you were describing when you said you cut out a square. THANK YOU!!!!
Old 12-25-2012, 01:40 AM   #9
bdiamond
I did a pair like this. I cut 3/4" and after blending looked factory.
bdiamond is offline   Reply With Quote
Old 12-25-2012, 01:33 PM   #10
SCOTI
SCOTI's Avatar
i recall that was the amount removed from mine as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-25-2012, 03:51 PM   #11
Rochlow
Could you move them forward to center the wheel in the wheel well?
Rochlow is offline   Reply With Quote
Old 12-25-2012, 04:53 PM   #12
LONGHAIR
Seems like you would have bump-steer issues with this?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-25-2012, 07:06 PM   #13
Realnoisy
Realnoisy's Avatar
I moved the xmember up the rails 1 inch to center in the wells. I have heard of stepping the arms instead of using dropped spindles to lower but never read anything about centering the wheels this way.
Old 12-26-2012, 10:49 AM   #14
SCOTI
SCOTI's Avatar
That could be done but would require larger diameter wheel to accommodate the change. I doubt 15" wheels would clear...
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-26-2012, 05:53 PM   #15
bdiamond
The No-Limit guy has a build thread where he moved the ball joint forward like an inch or more. Used a balljoint ring from Speedway and a holesaw. It looked kinda rough, but apparently it worked.
Old 05-10-2017, 03:17 PM   #16
Capo_Customs
Bringing this post back from the dead. What is the reasoning behind narrowing just the lower control arm?
Capo_Customs is offline   Reply With Quote
Old 05-10-2017, 04:02 PM   #17
tinydb84
tinydb84's Avatar
Most of us are lowered enough that the upper control arm needs a bunch of shims to fix the camber. If you shorten just the lower it will just require an alignment and not have as many shims.
It will slightly decrease the camber gain through the suspension cycle as well for those who like to roll a bit low.
David
Instagram: myfabguy
Old 02-25-2023, 11:21 AM   #18
5150
C10 Club Tennessee
5150's Avatar
Do you have a picture of it finished? Especially the uppers.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
