12-25-2012, 05:33 PM | #1 |
TD 366 timing
i have a 366 tall deck in my 86 swb and just dropped a new distributor in it a GM hei with a vacuum advance(last one didnt have one) what should i set the base timing at? its a pretty much stock BB
Headers(strait piped with cherry bombs) Performer 2.0(with spacers) carter carb unknown CMF the rest is bone stock |
12-27-2012, 12:18 AM | #2 |
Re: TD 366 timing
I like to set my low compression old school engines at 12-14 initial, and 36* total.
12-27-2012, 10:40 AM | #3 |
Re: TD 366 timing
need to do a little work on a sheet of paper, find out how much advance your vacuum can is worth if its not adjustable. i would find out what a bbc likes in total advance at cruise.
initial+vacuum+mechanical....on a sbc they tend to not like anymore than 50-52.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
12-27-2012, 07:07 PM | #4 |
Re: TD 366 timing
I set the initial at 8* it has a carter 650 AFB on it the newer style and now it seems to have a pretty large stumble in it on take off at idle and part throttle smashing of the peddle i dont have a vacuum gauge to set the idle mixture screws but they should not cause the part throttle bog or stumble right? is there any other way to set them
BTW i run 87 octane gas and some times a little bit of 93 |
12-27-2012, 07:08 PM | #5 |
Re: TD 366 timing
12-28-2012, 04:08 PM | #6 |
Re: TD 366 timing
Any one got any ideas this truck is my DD
