Old 11-28-2012, 09:29 PM   #76
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Parked Indefinite
Great stuff as usual! Love the wiper motor relocation!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 12-05-2012, 01:02 AM   #77
Desperado454
Desperado454's Avatar
Originally Posted by 3r!c84 View Post
sick set up! ill be watching this one
Thanks guys, tricky part is to figure out how to make the wiper linkage work again...
Originally Posted by legendman View Post
How about a motorcycle chain?
Love the outside the box thinking on this truck
Originally Posted by Dieselwrencher View Post
I bet with some machining you could make that work. But then you'd need to keep it lub'd well and then it'd sling the lube all over.
Had a few ideas how to make it happen, but having to deal with the oil mess is an issue. I just wanted to see what it would look like
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 12-05-2012, 01:12 AM   #78
Desperado454
Spent a few hours working on the bottom of the cab today. Managed to get everything ground down and sprayed on some "european texture" undercoat. Turned out okay, and finally got the cab bolted to the frame.
'28 Model A Build
-Brooks
Old 12-11-2012, 03:57 AM   #79
Desperado454
Small update:
Finished the wiper linkage and started planning the downpipes
'28 Model A Build
-Brooks
Old 12-11-2012, 09:57 AM   #80
96twodoor
96twodoor's Avatar
very nice work sir,keep the updates coming !
96twodoor is offline   Reply With Quote
Old 12-11-2012, 01:46 PM   #81
moneyeater
moneyeater's Avatar
you´re skilled and creative, why can´t you find a job?
Cool build by the way!
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 12-12-2012, 05:08 AM   #82
Desperado454
Will do!
Volker
Thanks! I have a job, just not that great of one
Anyways, tonight I remounted my fuse block to the top of the inner firewall which put the connector in the cowl area. I don't know how everybody else does this, but it seemed like it would work the best for me. I'm hoping water wont be too big of a problem, but I think it should be fine. Pics:
Connectors new home:
Wires come out here:
Next up will be making the downpipes
'28 Model A Build
-Brooks
Old 12-12-2012, 08:33 AM   #83
hyatt
Originally Posted by VA72C10 View Post
Looking good!
You should use a mid mount also or you may be breaking bellhousings due to twisting over the long distance between ft and rear mount I learned that the hard way on ft mounted 55-57 cars back in the day
hyatt is offline   Reply With Quote
Old 12-15-2012, 05:17 PM   #84
Desperado454
Hmm... might be an idea. What kind of power were you making? It might be tough to see, but it is rubber mounted if that makes any difference
Anyways, the downpipes are coming along
'28 Model A Build
-Brooks
Old 12-15-2012, 05:59 PM   #85
hyatt
The sheer lenth between the front mount and the trans mount puts too much stress on the bellhousing or trans case on automatics
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
Old 12-18-2012, 01:11 AM   #86
Desperado454
Filler time!
"The Bullet"
'28 Model A Build
-Brooks
Old 12-19-2012, 01:52 PM   #87
made2drag
made2drag's Avatar
nice build dude
made2drag is offline   Reply With Quote
Old 12-22-2012, 01:47 AM   #88
Desperado454
Originally Posted by made2drag View Post
nice build dude
Right arm
Still plugging away on the firewall, doesn't look that different but it's just about there.
'28 Model A Build
-Brooks
Old 12-24-2012, 01:11 AM   #89
Desperado454
Not too much to update on, just a progress pic. Hope to get some epoxy primer on it tomorrow. Also a pic of the blue that will be the main colour.
'28 Model A Build
-Brooks
Old 12-25-2012, 02:44 AM   #90
Desperado454
Got 'er primed! Was tempted to just leave it epoxied, but my want for a blue truck prevailed.
'28 Model A Build
-Brooks
Old 12-25-2012, 04:48 AM   #91
canadian trucker
A day should have 30 hours.
Wow, that looks so good black.
But blue will look sick
Keep up the great work.
canadian trucker is offline   Reply With Quote
Old 12-25-2012, 10:21 AM   #92
canadian 4x4
canadian 4x4's Avatar
Looks awesome! Loving the build
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
Old 12-26-2012, 09:29 AM   #93
rusty76
rusty76's Avatar
Killer build man. I just read the whole deal and I'm impressed! I've got a few questions for ya. I know you channeled your truck but how much was it lowered before and the channel and how? Also what size tires you running? Thanks.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-26-2012, 11:00 PM   #94
Desperado454
Did a homebrew axle flip on the back which i think netted around 6" and the front was 3" spindles and 2" coils. In hindsight I wish I had just cut the stock coils. Tires are just some basic 235/75/15's.
'28 Model A Build
-Brooks
Old 12-28-2012, 03:07 AM   #95
Desperado454
Hopefully all I'll need to endure tomorrow is a final bout of sanding so I can spray the base coat/clear coat on the firewall and surrounding areas. Nowhere near perfect, but should be good enough for a driver. Here's a pic of how it's coming along:
'28 Model A Build
-Brooks
Old 12-28-2012, 11:19 AM   #96
3r!c84
Badass
3r!c84's Avatar
What kind of shocks are thos? Looks like some sort of coil spring lol
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-29-2012, 01:09 AM   #97
Desperado454
I guess they're just some sort of coil over shock. They've been on the truck since I've bought it and have been meaning to take the spring off to see if it would drop the truck any. As you can see that hasn't happened yet.
Anyways, firewall is painted. Came out so so, might sand and buff it in a few days, but I'll see how it looks in the morning. The blue is really dark, so I took this pic with the shop lights off and a work light on. I'll get some better pics eventually.
'28 Model A Build
-Brooks
Old 12-29-2012, 11:47 PM   #98
Desperado454
Going to try to sand and buff the firewall down tomorrow as it is still pretty rough. The blue came out darker than I thought, but definitely comes alive in the light. Few more pics:
'28 Model A Build
-Brooks
Old 12-30-2012, 07:11 AM   #99
moneyeater
moneyeater's Avatar
Great work! Keep it up!
Volker
Come have a look!
Old 12-31-2012, 04:59 AM   #100
Desperado454
Volker
Thanks!
Sanded and buffed the firewall this morning, and ended up looking a little better. Still pretty bummed about it though. Oh well, it's just the firewall, and now I can focus on getting the engine back in. So that's what I spent the afternoon doing. Welded oil drains into the pan and started laying some paint on the mill. The pics to follow are how the the firewall ended up and some of the boiler itself. Covers still need to be cleaned up some...
'28 Model A Build
-Brooks
