Old 12-26-2012, 10:22 PM   #1
Longhorn 70
Longhorn 70's Avatar
Has anyone replaced 70 3/4 ton rear wheel studs with 9/16?
Hi.
I have a 70 3/4 ton with free floating rear axle and am replacing front drums with disc. The front disc have 9/16" studs. Are there REAR studs that are 9/16" that are press in for the ones in there now?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-26-2012, 10:35 PM   #2
SS Tim
SS Tim's Avatar
Re: Has anyone replaced 70 3/4 ton rear wheel studs with 9/16?
Davepl modified his Longhorn to 9/16" studs for the same reason.
http://67-72chevytrucks.com/vboard/s...d.php?t=543067
SS Tim is offline   Reply With Quote
Old 12-27-2012, 11:07 AM   #3
Longhorn 70
Thanks. My search didn't return any results. I must not have spelled correctly.
Old 12-27-2012, 08:39 PM   #4
I did this on all four corners on a '70 CST/30 I had that I put chrome Budds on,since those were all made for later disc brake trucks. Just be sure to drill undersized so the stud splines will "cut" themselves in when pressed in.
Old 12-27-2012, 10:14 PM   #5
72MARIO
72MARIO's Avatar
I have a 1970 dana 60. I drilled out the hub and pressed in 9/16. I think in 71 they changed to the 9/16.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-27-2012, 10:16 PM   #6
Longhorn 70
I was hoping there were 9/16 studs that pressed into the 1/2 stud holes.
Maybe I'll just live with 1/2 on the rear for now. Maybe put disc on the rear later. I don't trust myself with a hand drill and I have given my drill press away. OR I guess I could find another drill press and resell on CL when I am done with it.
Old 12-27-2012, 10:44 PM   #7
CrewCab59
CrewCab59's Avatar
You don't need a drill press. Here is a link for studs. https://www.dormanproducts.com/catal...ec10_Part4.pdf
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 12-27-2012, 11:15 PM   #8
Longhorn 70
Thanks!! I'll remove one of the rears and find one with the knurl and length that is close. That really helps.
Thanks again.
Old 12-27-2012, 11:52 PM   #9
CrewCab59
CrewCab59's Avatar
Thanks again.
You can go to autozone , use truck info and they list the 2 studs with all info per coil or leaf springs. That way you don't have to remove the stud to check.
1971 Chevy C/10
