#126 | |
Re: 94 Suburban to Crew Build: The 50/50 Turban
Keep plugging away, you will get things to flow.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
#127 |
a little boxing of the rear rails and you'll be fine.
this just looks like a whole lot of work for a extended cab 4 door? |
#128 |
Professional Crow Bar Tosser
It's really just an optical illusion. Frame is straight front to back.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" Last edited by Dub_X; 12-28-2012 at 12:40 PM. |
#129 | |
And when it's all done, a tough one at that.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" |
#130 |
Look at any 88-98 frame and it curves in and out from front to back, it is 95 percent of the suburban frame capped with a stronger frame. That is no where near a finished product. We decided to try this frame first and see what happens. If it dont work out it will still make scrap. Anyway as far as a lot of work ... Its ok because its the first truck we built welding two together like this and if it flops so what its a learning tool. and as far as getting the frame true front to back, crossmembers and boxing will take care of that. In the end if we dont like it we will scrap it and try something else, and loose nothing but time since we have next to nothing in it.
2000 Chevrolet Silverado Z71 ![]() 1965 Chevy C-10 on '61 Apache Frame [90s Build] 1997 3500 Chevrolet Custom Mega Cab Project My son's '92/'93/'94 GMC K2500 Conversion Project |
#131 |
We learn more with each comment or sugestion from those of you that have already been there and done that. THANKS for that.
![]() Sometimes a guy just has to try it himself to figure out if it works for him or not. I think thats where we have been on the frame. We are going to continue to work on the cab and set the frame aside for now... Norm
#132 |
Here's some frame comparisons, left and right sides, of the bends in the frames.
One is the crew cab frame. Frame is stock and unmodified up until the added 2 ton rails. Other frame is my '93 Ext. cab shortbed Z71 4x4 frame, which is stripped down and completely stock, unmodified, and never wrecked. This is for those that pointed out that the frame looks bent out of whack.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" Last edited by Dub_X; 01-07-2013 at 09:34 PM. |
#133 |
Do u have any new uodates like what you are doing with the interior in the rear of the cab I like the mega cab look but not sure how the interior will look ? I am thinking about doing this my self the same
Posted via Mobile Device |
#134 |
Right now we're just doing minor work to the cab. This one is pretty much on hold while I work on my Z71 project. We're still throwing around ideas for the interior in the back of the cab, so we're not sure what we're gonna do with it yet.
#135 |
Any reports or updates? This was a cool build! What happened?
My names Tye. No Chevy right now ![]() |
#136 |
Still working on it, it was just put on hold while we got to work on my truck. Gotta finish up work to my truck, and then it's back to work on the crew. We have the drivetrain and everything for it, we just have to work with it, and finish building it. Still have a lot of work to do to the cab, and we're going to go back through the frame.
#137 |
Hey, I have been following this thread with a great deal of interest. Down here I have stretched a couple of 86 cc dually's into transporter ramp trucks. The latest one has a 49 White fire cab dropped 8" over the rails. It has full suspension travel and is only 4" off the ground. Usually I just get a 6' to 9' section of 4500 rail and insert just in front of the rear springs, cut on a 45 degree in vertical and 90 degree across the top and bottom. Then "fish plates" about 18" long with diamond ends for welding inside and out, on every face. The finished trucks can carry a load up to 4500kg. The biggest thing is setting up that the rails are square and flat to less than 1/8" on any cross section measurement. For the welding I usually tack everything with the mig and then when happy I get out the "gold tipped chassis rods" for the stick welder and sit down for a couple of hours. Don't forget to check the pinion angle on the diff!
Terrick |
#138 |
Lots of good info Thanks, We have decided to use a rear frame section from another 4x4 and splice it under the cab, I will fish plate it then box in the frame over the splice. We will look at several frame splices and use what we like best.
#139 |
An idea, have you thoughtvabout finding a 92-99 cclb frame and shortening it to the desired length? What about the driveshaft, and fuel and brake lines?
#140 |
We have looked at many frame options but we have decided to use the parts that we have now... by splicing in the back of the frame from the other 4x4 frame we would have all of the mounts for the fuel tank, rear springs, shocks bumper, bed and rear of the cab. We will have to have a rear drive shaft made and run new fuel and brake lines. The front drive shaft will work as it is...
#141 |
do you have anymore updates right now?
And in the end, it’s not the years in your life that count. It’s the life in your years.” — Abraham Lincoln |
#142 |
Not really. Sad to say it's been put off the past year. We're working at getting it finished hopefully within the next few months though and finally put it back on the road. Too many things to do and not enough time. That's always the problem.
#143 |
We have a MAJOR MAJOR update.
First of all. The crew crab/two ton crossbreed frame...scrap. Now it's time to post what we have for the new home for the crew cab. Firstly...Vortec ![]() ![]()
#144 |
So. It's a 97 Silverado, one ton, 350 Vortec, 4L80E.
#145 |
Hideous bed...came off. And we singled it out.
#146 |
Went ahead and threw a temporary bed on it, then picked up some new rims to finish singling it out. 16X8 American Racing Nitros.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now then. The plan with this beast. It has a 350 Vortec and 4L80, the body is trashed, and the interior is...well the truck sat out in a pasture for three years, rat nests galore...we want NOTHING to do with the body. So we're gonna do a little modifying, use the entire running gear, and the crew cab is going on this frame.
#147 |
Very nice....more please.lol
#148 |
Nah I think you can wait
#149 |
Dubs truck wont take that long to finish and then the crew will get finished
#150 | |
