djm lower control arm shock mounting
the djm lower arms i put on my blazer have very large shock bolts that wont fit though stock or belltech shocks.anyone ran into this before?do i need to buy djm shocks?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: djm lower control arm shock mounting
Do you have any pics?
Does it have a bolt or a shock stud?
I had the same problem when I installed my djm arms. I just took out the metal insert on the shock and it fit. I also had to buy different size of spacers.
It was kinda frustrating, but I did this on a Sunday and needed the truck for Monday so I didn't call jdm to ask about it.
![]() ![]() It ain't yours, if you didn't build it! |
djms have a regular bolt with a spacer that goes into a threaded part of the a-arm.
thanks for the reply.i think i am going too cut out the incorrect sized nuts on the arms and weld in the proper ones.tried to remove the sleeve on the shocks
and they would not budge. |
Old thread, I know. I'm running into this issue now too. It was my stopping point for yesterday.
http://http://67-72chevytrucks.com/v...d.php?t=578181 |
ended up drilling shock bushing out so the bolt would fit.think i used a 5/8" drill bit
It was pressed in? How was it adhered to the rubber portion around the bushing? Unfortunate. Im going to try to press mine out before drilling. But thanks for the help, I'll probably do the same.
they are belltech shocks and i could not press out the bushing-it was like the rubber was poured around the bushing.i just drilled it to 5/8 and there is still bushing material left.but you shocks may be differnt.
![]() Join Date: Mar 2012
Pics always make it much easier to get answers
![]() Posted via Mobile Device
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
I drilled mine out, forgot what size bit I used. After a while the bushing and rubber got hot and then bushing came out.
