Old 12-29-2012, 06:23 PM   #1
srvivor71
srvivor71's Avatar
Engine Bay / Engine Positon
I look at all the engine bay pics I can find and am puzzled about something. How come some engines (like mine - a 350) are buried in the firewall with no clearance for the air cleaner and REALLY bad access to the distributor and both dipsticks and some seem to be much further out in the bay, with lots of access to the further back stuff? Does being a 4x4 make a difference?
srvivor71 is offline   Reply With Quote
Old 12-29-2012, 06:42 PM   #2
blkcorvair
blkcorvair's Avatar
Re: Engine Bay / Engine Positon
buried in a firewall usually means someone did a swap from an I-6 and left the I-6 stands in just bolting the v-8 to them. The actual V-8 stands sit a couple inces foward.
I have also read that the 4wd engine setup sits further back, but I cannot confirm this
blkcorvair is offline   Reply With Quote
Old 12-29-2012, 07:02 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
This is basically correct.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-29-2012, 07:12 PM   #4
SS Tim
SS Tim's Avatar
The 4x4s and I-6 trucks use the aft mounting position. V-8 engines and transmissions are mounted about 3.8" further forward from the factory.
SS Tim is offline   Reply With Quote
Old 12-29-2012, 08:21 PM   #5
srvivor71
srvivor71's Avatar
Mine has the factory original 350, so I guess it's because it's a 4x4...? I can tell you, it is a pain in the neck working on anything in the back of the engine.
Old 12-29-2012, 08:32 PM   #6
SS Tim
SS Tim's Avatar
Some people would use that as an excuse to add a doubler to the transfer case or an O/D trans. and move everything forward to fit. Then axle clearance becomes an issue and a lift is needed.
engine bay, engine position.
