Old 12-30-2012, 02:18 AM   #1
65GMCFirstride
65GMCFirstride's Avatar
Aftermarket Guages
I have a 65 GMC truck and I am installing new dolphin gauges. I have researched a lot on the forum and understand that I need a 0-90 ohm fuel sending unit. I know GM changed from 30 to 90 ohm in 1967. Does a 1967 fit a 1965 tank?
Or, do you know someone that can change the resistor?
Thanks!
65GMCFirstride is offline   Reply With Quote
Old 12-30-2012, 03:12 AM   #2
Mack B
Mack B's Avatar
Re: Aftermarket Guages
Did you get a sender with your dolphin gauge set? It can be modified to work with your stock pick up assembly. Side note: if I made these up would people buy them? Wat? I'm lookin to be a CEO
Mack B is offline   Reply With Quote
Old 12-30-2012, 12:36 PM   #3
65GMCFirstride
They sent a dolphin sending unit with the gauges. It is way different than stock which makes me think that would be an undertaking. Is it difficult and risky since I would be messing around with electrical current and gas?
Old 12-30-2012, 12:45 PM   #4
Mack B
Mack B's Avatar
Dat der pic is just that, a dolphin sender on the stock pick up. It's really not an undertaking, I may have 30 mins in this. I washed n dried the pick up, then stuck a lighter to it before I welded on it tho.
Old 12-30-2012, 04:46 PM   #5
hotrodder
Thumbs up Re: Aftermarket Guages
Like he said it is easy to do. I also have dolphin guages in my 63 and neede to do the same fix. I was very thankful for the pics and instructions.
hotrodder is offline   Reply With Quote
Old 12-30-2012, 08:12 PM   #6
Hx16457
Hx16457's Avatar
I need one for sure! I have dolphin ga. And did not think of what you did and broke the sending unit that came with the gauge set. I might be able to salvage it. Can you give me the "instructions for dummies" version?
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 12-30-2012, 08:54 PM   #7
Mack B
Mack B's Avatar
Check your Pm sir!
Old 12-30-2012, 09:20 PM   #8
Hx16457
Hx16457's Avatar
Thx again for the info!
Old 12-30-2012, 09:26 PM   #9
65GMCFirstride
Mack B, I would appreciate the instructions as well. Thanks!
Old 12-31-2012, 12:01 AM   #10
Mack B
Mack B's Avatar
Pm'd it to you, imma go ahead and post it here incase anyone else wants to give it a go
I was nervous about welding on something that has been soaking in gas for 50 years, first thing I would do is wash it thoroughly then do "the lighter test" lol.
Here is the stock unit, I just kinda twisted on the mount till the spot welds broke
Then I took the new sender off the mount, and shaped the float rod (I believe I had to cut some off) to closely match the stock shape.
Then clamped the new sender to the old pickup tube so the arm was close to the stock position, and tac welded it in a few places along the tube (jb weld would probably work)
Then trimmed the wire from the sender down and sandwiched it usining the plastic bushings and used the hole in the top plate where the stock wire fed through (I believe I had to trim the bushing to fit)
Hope that helps some!
