Old 12-30-2012, 12:28 PM   #1
UATahoe
Upgraded fuel tank selector valve???
I am in the process of installing a 383 in my 87 R10 pickup. Keeping the tbi system. Fuel pressure is being bumped up and I have been told it would be a good idea to replace my fuel tank selector valve with one that can handle the extra fuel pressure. Anybody else have to do this?
UATahoe is offline   Reply With Quote
Old 12-31-2012, 01:19 AM   #2
wyattglock
wyattglock's Avatar
Re: Upgraded fuel tank selector valve???
Considering the stock fuel pressure is between 9-11 psi, generally speaking. Unless you are going to 40+ psi, I would think the valve will work just fine. I would be more worried about consistent fuel pressure. Which an aftermarket regulator would solve that problem.
wyattglock is offline   Reply With Quote
Old 12-31-2012, 10:43 PM   #3
rfmaster
rfmaster's Avatar
Pollack switches can handle up to 65 PSI per the data sheet.
http://products.pollakaftermarket.co...-valve/42-159?
Happy New Year
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 12-31-2012, 10:57 PM   #4
UATahoe
So this would be a direct replacement?
Old 12-31-2012, 11:12 PM   #5
rfmaster
rfmaster's Avatar
Yes, this as close to OE replacement, but minor modifications may be required to fuel line hoses and wiring. Get a complete kit with pigtail plug.
//RF
"The Beast"
Old 12-31-2012, 11:16 PM   #6
UATahoe
The switch in the cab will remain the same though right? The kit I saw came with a pigtail and a toggle switch but I would rather keep the in cab switch stock. Also, do you think this will be necessary? I am only planning to run the system at 18 psi and replacing the stock injectors with a set of the higher flowing police car injectors.
Old 12-31-2012, 11:36 PM   #7
wyattglock
wyattglock's Avatar
Happy New Year
//RF
That's good to know. I had never looked that up. Thanks RF!
