Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-16-2012, 01:52 PM   #51
Dale99
Re: Project 30 years sitting
Dale99 is offline   Reply With Quote
Old 12-18-2012, 09:49 AM   #52
Dale99
95% of my exhaust. Trying to decide how to do the exits.
Old 12-20-2012, 11:22 AM   #53
Dale99
new rubber came in 7 days early
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Old 12-21-2012, 11:28 PM   #54
Dale99
Got the tires on it, looks like a 4x4 now.
Went to run it off the new tank/electric pump tonight. Blew out the carb gaskets. The inline regulator was suppose to be pre-set at 7psi, but somehow got up to 10-12'ish and sprayed fuel everywhere.
Old 12-23-2012, 09:35 PM   #55
Dale99
Full exhaust done
2nd fuel regulator on, and its not the right one, but it runs on a correct fuel tank
vent lines routed and breathers mounted for axles
waisted 3hrs in the middle of the day for work, ugh
Old 12-24-2012, 12:22 PM   #56
Dale99
In this first image. Can someone tell me the name of this part?
2nd image is all thats left of my exhaust build. I would say I designed it fairly well.
Old 12-24-2012, 12:27 PM   #57
Dale99
new tires on...
Old 12-24-2012, 01:00 PM   #58
hgs_notes
GEARHEAD
hgs_notes's Avatar
Is that the top of the door window frame? If it is there is a plastic piece that goes there to close off the cut end of the window frame.
hgs_notes is offline   Reply With Quote
Old 12-24-2012, 01:15 PM   #59
Dale99
Thats where the "a"post joins with the removable top. I have the plastic thing on both doors. But this metal thing, I only have it on the pass side.
Old 12-24-2012, 06:13 PM   #60
hgs_notes
GEARHEAD
hgs_notes's Avatar
I think that was part of the original seal set for the top where it meets the door glass. I think the new ones are made differently and if needed, the metal part should come with the new seals.
Old 12-24-2012, 07:47 PM   #61
Dale99
huh, ok. New seals are on my next lmc order.
Old 12-24-2012, 08:46 PM   #62
Dale99
original goal met after a few setbacks.
http://www.youtube.com/watch?v=sJCg6...ature=youtu.be
Needs ball joints bad as its all over the road. Needs carb tuned and I have no clue how to do that.
Old 12-24-2012, 09:33 PM   #63
thelonerife
thelonerife's Avatar
says videos private
thelonerife is offline   Reply With Quote
Old 12-24-2012, 11:44 PM   #64
Dale99
fixed, sorry
Old 12-25-2012, 08:30 PM   #65
hgs_notes
GEARHEAD
hgs_notes's Avatar
Congratulations! Getting it to move under its own power is always a plus. Sounds pretty good, if a bit doggie. Didn't sound like much with carb issues though. Might just need more advance on the timing. I like how the exhaust sounds.
Old 12-27-2012, 05:38 PM   #66
Dale99
Still working on it running right issues. We can get it to idle and rev great in park. But you put it in gear and put a load on it, and it just bogs down n stalls.
But I did drive it around the neighborhood in the snow/ice since you dont need to go fast anyway. Lots of looks, smiles, and waves
Ordered the bolts and spacers for a body lift. Wow that was expensive Still need to order the new mounts.
Old 12-27-2012, 06:28 PM   #67
hgs_notes
GEARHEAD
hgs_notes's Avatar
Sounds like a vacuum leak. Check the hoses and connections, also the brake booster and around carb and manifold. You guys have more snow than we do, but I bet its warmer.
Old 12-27-2012, 07:08 PM   #68
Dale99
When we first started it, we slowly connected things checking vac. As we have added, nothing changed.
Old 12-27-2012, 07:48 PM   #69
hgs_notes
GEARHEAD
hgs_notes's Avatar
Got a vac gauge? It changes with timing also, or if a valve is out of adjustment. Same symptoms I had with my jimmy. I had to adjust the valves to get the vacuum back.
Old 12-27-2012, 09:11 PM   #70
Dale99
Yea, we have had a gauge on it while adding all the stuff. I installed an incab one so I can monitor while driving.
Old 12-28-2012, 10:12 AM   #71
hgs_notes
GEARHEAD
hgs_notes's Avatar
Sounds like you have that covered then. Good luck with the rest of the tuning. I've got a carb rebuild kit sitting on my air filter right now so when the day comes I can actually take it for a drive I'll have it ready.
Old 12-29-2012, 12:28 PM   #72
Dale99
junkyard score!!
dash speaker grate
dash speaker
speaker bracket
headlight switch
dual horn setup... only got one horn as I have one already and didnt have tool to grab the second.
tow hooks that can easily be modded and installed.
Old 12-29-2012, 02:35 PM   #73
Dale99
Adjusted timing up to 20deg. Runs 1000x better. Now to fix this brake light thats stuck on in the dash. Bad prop valve?
Old 12-29-2012, 09:32 PM   #74
jaros44sr
jaros44sr's Avatar
Nah, valve just has to be centered....cool, glad its running better for you
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-30-2012, 12:56 PM   #75
hgs_notes
GEARHEAD
hgs_notes's Avatar
