Old 12-30-2012, 07:23 PM   #1
STPrider
STPrider's Avatar
water trap questions
Hey guys, putting a water trap in my air suspension system. Can it be any air water trap or should it be specific to air suspension? And should I mount it in the line from the compressor to the tank or the line from the tank to the valves? Thanks,
-Derek
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 12-30-2012, 08:55 PM   #2
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Re: water trap questions
Since condensation occurs as a byproduct of compressing and decompressing air, I put mine after the tank before the valves. This will keep a majority of the moisture out of the rest of your system. Putting one before the tank, won't trap the moisture in the air when decompressing the tank. It's there trust me. I work on pressurization systems for aircraft. I used a trap from a vender on the forum. Always wanna give them the business first when you can.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 01-01-2013, 10:28 AM   #3
see ten
WTB this ad
see ten's Avatar
I have a water trap between the compressor and my tank, a petcock on the bottom of the tank, and a water trap between the tank and the valves. This is how it was suggested to me by the guys at Accuair when I used their setup a few years ago.
see ten is offline   Reply With Quote
Old 01-01-2013, 02:24 PM   #4
STPrider
STPrider's Avatar
Thanks for the replies, I have a water trap and a drain cock at the bottom of the tank, I'll see how that workd for a while and maybe install a second trap between the compressor and tank... see ten was there more water in either trap or were they fairly equal?
Old 01-01-2013, 04:19 PM   #5
see ten
WTB this ad
see ten's Avatar
The trap between the compressor and tank always had the most in it. But there is always moisture from the other two points as well. Of course, they're "downstream" from the first so...
Old 01-01-2013, 04:32 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Hey seeten... do you have any pictures of your air ride setup on the caddy?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-03-2013, 04:44 PM   #7
see ten
WTB this ad
see ten's Avatar
Old 01-03-2013, 08:41 PM   #8
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
http://www.avsontheweb.com/home.php?cat=322
We manufacture water traps for air ride set ups. They are available in a few different colors and sizes...
AVS_JASON is offline   Reply With Quote
Old 01-06-2013, 01:55 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks see ten!
-Nate
Old 02-29-2016, 12:34 PM   #10
jondancer
So on a dual tank, dual compressor setup , where would u put the trap ?
jondancer is offline   Reply With Quote
